lappir Posted December 18, 2021 Report Share Posted December 18, 2021 17 hours ago, KodiakJack said: Just installed a new Oxygenics shower head and love it. Different from our original with built in shut off and 2 setting adjustable sprays. Only place I could find it was at Lowes. Later, J https://www.lowes.com/pd/Oxygenics-BodySpa-Adventure-RV-Brushed-Nickel-3-Spray-Handheld-Shower-1-8-GPM-6-8-LPM/5013049769 Got one too a year or so ago. Not at Lowes, though. It's a good unit so far. If you want to conserve water it's one that does it the best that I have found. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
franco-bolli Posted January 21, 2022 Report Share Posted January 21, 2022 I added one of these ( or one very similar to this) just after the pump, with a valve to disconnect it from the system during winterization. Much like the water heater, I don't want a bunch of anti-freeze in there 'cause it's hard to get rid of it all if it gets in there. https://www.lowes.com/pd/EASTMAN-Thermal-Expansion-Tank-2-Gallon-Universal-Steel-Water-Heater-Pressure-Regulator/5000087243 I pumped it to 50lbs. I'm amazed at how long it will push water before the pump cycles on. The pump no longer "pulses" when the faucet is less than 1/2 open or at any time in a shower. Benefit #2 is I can get 2 to 3 toilet flushes at night and no pump cycle. 😁 Once winterization juice is in the lines, and the system is no longer under constant pressure, I open the valve to the tank again to allow for additional expansion of any remaining drops of water in the tank shoud it get below freezing (again). Fortunately there is enough room under the bench seat near the pump to anchor the tank down on it's side. Safe travels, FB Quote +++++++++++_____________________________________+++++++++++ 2021 Ram 3500 2017 Arctic Fox 25W(to be traded??) HAM guy (Ke7FIX), photography, woodworking (mostly sawdust), Electronics Technician, USAF DAV Going where everyone has gone before Link to comment Share on other sites More sharing options...
