Jim Corey Posted July 18, 2016 Report Share Posted July 18, 2016 I want to install a See Level tank level monitoring system on my 2006 Monaco Monarch. Also need to lube dump valve cables. Can I get to tanks (black, gray and fresh) by removing large plastic "control" panel in wet bay? It won't be easy to remove, but that looks like my only option. I don't want to pull the panel if it won't access the tanks. Jim Corey 2006 Monaco Monarch 30 pdd '12 Honda CRV toad Link to comment Share on other sites More sharing options...
Pat & Pete Posted July 18, 2016 Report Share Posted July 18, 2016 I looked at doing a similar operation on our 2000 Monarch . Our panel is still in it's original position as I saw no way to really do what I wanted without major pains . I use a push rod to totally close the black valve because the cable makes a pretty fair dip and never totally closed the valve . I push on the gate valve rod 'nut' and that closes it tight . Both cables get lubed via a small hole I drilled in the T handle rod collars on the outside of the panel . The holes are drilled deep enough to see the shafts move and at about a 45° angle . The little red tubes that come on spray lube cans fits nicely into those holes , but I still hold a rag around the area to catch what gets blown out . I also reach under the panel and lube the rods for the gate valves occasionally , which helps a lot . I have no idea how you'd get to the tanks to install a level indicator . We never use them , other than the sound we recognize as the black reaching full and the difference the drain makes for the grey . A lot of times we simply go by time . The black gets dumped about every third time for the grey . Goes around , comes around . Link to comment Share on other sites More sharing options...
Jim Corey Posted July 18, 2016 Author Report Share Posted July 18, 2016 Your method of sensing tank levels is what most of us use☺. About as accurate as the factory sensors. But I'd like a little better indication, particularly when boondocking. Jim Corey 2006 Monaco Monarch 30 pdd '12 Honda CRV toad Link to comment Share on other sites More sharing options...
