Sandra1953 Posted May 30, 2016 Report Share Posted May 30, 2016 Need advice. When unhitching my trailer, I was unable to get the ball to release from the hitch. Being new at this, I thought that I needed to elevate the tongue higher. As it turns out, I had to move the truck an inch to get them to separate. Now, I have a different problem. I can't retract the tongue jack far enough to get the base off of the blocks. I really need advice. The blocks are Lynx level caps, so if I can just get it high enough, I can shove one out. Sandy Link to comment Share on other sites More sharing options...
Kirk W Posted May 30, 2016 Report Share Posted May 30, 2016 You have a couple of different ways that this can be done. One would be to use the automobile jack to lift the trailer tongue higher. Place blocks under the auto-jack so that it will go high enough but not so many that you won't be able to get it out after you remove one block or so. Another way is to raise the tongue as high as possible with your tongue-jack and place something under the tongue to support it will you raise the tongue-jack enough to remove a block. Of course, all of this is with the trailer unhooked from the tow vehicle. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Devilishjim Posted May 30, 2016 Report Share Posted May 30, 2016 Put blocks under hitch and then lower trailer back down so you can get a block out then go back up and get the blocks out from under the hitch you may need to do this process a couple times Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
budeneighe Posted May 30, 2016 Report Share Posted May 30, 2016 Either way, be sure to solidly chock your wheels in both directions.... please. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
Sandra1953 Posted May 30, 2016 Author Report Share Posted May 30, 2016 Thanks, everybody. Got it taken care of with the help of some friends here who must have talked to you, because they had the same ideas. Sandy Link to comment Share on other sites More sharing options...
