On The Road Posted April 16, 2016 Report Share Posted April 16, 2016 I am learning and installing solar, Jack's web site has helped a lot plus Jack had given me some information. There is a lot to learn and the correct way to install. I am using a WindyNation MPPA solar controller with remote panel and a battery temp. I am installing two 265 watt high voltage panels, I found out the shipping is what makes the solar panels expensive. I am using Grape solar and they are sold by Home Depot with free shipping to home or store. They will come by freight. I found them on sale, which I think is a decent deal here http://www.homedepot.com/p/Grape-Solar-265-Watt-Polycrystalline-Solar-Panel-2-Pack-GS-P60-265-Fab2x2/206365797%C2'> They are 600.00 for the 530 watts shipped. On sale until the 4/30. I have 6 awg wire from the roof, which I think I could have gotten by with less. I only have enough real estate for the two panels. Trying to figure a combiner box or should I just connect the two panels to the 6 awg and seal the connection. Should have it complete sometime this next week. "> 2001 610 Volvo -Volvo power 465HP/1650 -autoshift2009 Smart Passion / cross loaded on Volvo2014.5 Mobile Suite 41 RSSB4VOLUNTEER CHRISTIAN BUILDERS Link to comment Share on other sites More sharing options...
whatsnext Posted April 16, 2016 Report Share Posted April 16, 2016 Depending on the dims of your panels, you may want to reinforce in the middle to minimize any flex as you travel down the road. My $.02 2016 Volvo VNL780 D13 I-Shift 2016 DRV 44 Houston 2015 Smart Cabriolet Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 16, 2016 Report Share Posted April 16, 2016 Consider running each panels wire down to a combiner inside the coach. This allows you to put a breaker on each panel, which also serves as your disconnect device - on both ends of the controller. See THIS for the gory details. (you probably already saw it..) It also has design examples in it that can step people through decision making. If you want to use the existing #6 then for two panels just put in either a purchased combiner, like the AM Solar one, or build your own. The article above will step you through several solutions. From crude to sophisticated. Do make sure you support the panels if they flex on their long dimension. To simplify the wiring you "can" wire serial, since you have an MPPT controller. Make sure it can handle the voltage...but it should. There are not many of the "restricted voltage" controllers left on the market. If doing that then you can simply lug together the #6 and #10 from the panels, and then tape them to keep it from working loose. Just put it into a junction box and go down through the bottom of that. This is the simplest wiring solution, but there are some negatives, relative to shading, for serial panels. Again, you likely know this by now. If you select #2 or #4 then for disconnects just use automotive re-settable breakers as I indicate in the article above. One on each side of the controller. Make sure the "array side" breaker support the voltage. The ones I reference should. There is far more detail in the article. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
On The Road Posted April 16, 2016 Author Report Share Posted April 16, 2016 Consider running each panels wire down to a combiner inside the coach. This allows you to put a breaker on each panel, which also serves as your disconnect device - on both ends of the controller. See THIS for the gory details. (you probably already saw it..) It also has design examples in it that can step people through decision making. If you want to use the existing #6 then for two panels just put in either a purchased combiner, like the AM Solar one, or build your own. The article above will step you through several solutions. From crude to sophisticated. Do make sure you support the panels if they flex on their long dimension. To simplify the wiring you "can" wire serial, since you have an MPPT controller. Make sure it can handle the voltage...but it should. There are not many of the "restricted voltage" controllers left on the market. If doing that then you can simply lug together the #6 and #10 from the panels, and then tape them to keep it from working loose. Just put it into a junction box and go down through the bottom of that. This is the simplest wiring solution, but there are some negatives, relative to shading, for serial panels. Again, you likely know this by now. If you select #2 or #4 then for disconnects just use automotive re-settable breakers as I indicate in the article above. One on each side of the controller. Make sure the "array side" breaker support the voltage. The ones I reference should. There is far more detail in the article 1. I am unable to get the wire from the roof to the controller. The 6 awg was installed when the coach was built. 2. I will make a combiner box or connect together in two boxes on the roof. Then tape the connection to insure moisture resistance. 3. I have 8 supports for each panel, I am thinking three on each side and one on each end. If it still flexes I can add more. 4 I believe these panels are rated at about 8.56 amps each 265 watts divided by 30.96 volts would equal the 8.56. My controller is 30 amps so should be ok. 5. I am using re-settable 30 amp breakers on both sides of the controller. The wiring on the roof will be 10 awg double layer MC4 solar cable and the 6 awg is also double layer solar wire or is suppose to be. That is what I paid for. "> 2001 610 Volvo -Volvo power 465HP/1650 -autoshift2009 Smart Passion / cross loaded on Volvo2014.5 Mobile Suite 41 RSSB4VOLUNTEER CHRISTIAN BUILDERS Link to comment Share on other sites More sharing options...
On The Road Posted April 16, 2016 Author Report Share Posted April 16, 2016 Depending on the dims of your panels, you may want to reinforce in the middle to minimize any flex as you travel down the road. My $.02 My panels are 39" x 65" "> 2001 610 Volvo -Volvo power 465HP/1650 -autoshift2009 Smart Passion / cross loaded on Volvo2014.5 Mobile Suite 41 RSSB4VOLUNTEER CHRISTIAN BUILDERS Link to comment Share on other sites More sharing options...
