GVJeeper Posted December 29, 2015 Report Share Posted December 29, 2015 I have a 2013 Rockwood TT where the TV slides down into the cupboard below it. A while back I bought a bigger TV and just set it on that counter top. I just tried a DVD and it would show on the TV. I have a Genesis panel that controls the surround sound, radio, etc. I think I forgot to hook something up when I got the new TV. Right now I have my DirecTV DVR and PS3 hooked up to the TV. The TV also can receive park TV when I switch input to Cable. I checked all the inputs choices and none worked...which I expected since I'm sure I much run something from the Genesis to the TV..any ideas? Link to comment Share on other sites More sharing options...
Yarome Posted December 29, 2015 Report Share Posted December 29, 2015 Model? For the GT2.0 or 3.0 DVD manual you might check here. Link to comment Share on other sites More sharing options...
Kirk W Posted December 29, 2015 Report Share Posted December 29, 2015 . I just tried a DVD and it would show on the TV...... . I think I forgot to hook something up when I got the new TV. (emphasis added) Am I correct to assume that you mean that the DVD player does not show on the TV? If you could post some pictures of what you have it might also be helpful. Link to comment Share on other sites More sharing options...
GVJeeper Posted December 30, 2015 Author Report Share Posted December 30, 2015 I FOUND IT!!!! I had to remove the fireplace and hunt through a ton of wires and cable to finally come across an HDMI cable not hooked to anything. Hooked it to the TV and it worked. Link to comment Share on other sites More sharing options...
Kirk W Posted December 30, 2015 Report Share Posted December 30, 2015 I had to remove the fireplace and hunt through a ton of wires and cable to finally come across an HDMI cable not hooked to anything. Hooked it to the TV and it worked. Good work! Nothing like success to make for a good day. Link to comment Share on other sites More sharing options...
