GlennWest Posted December 3, 2015 Report Share Posted December 3, 2015 Our Teton has the DeWald Manufacturing system on our slide outs. It works slides fine. It also continues to cycle pump for up to 30 minutes after the slides are in or out. It just started this. Is this a sign of low fluid? It is annoying and disturbs our pets. Link to comment Share on other sites More sharing options...
HamRad Posted December 4, 2015 Report Share Posted December 4, 2015 I would guess that it is indeed a sign of hydraulic fluid being low. Have you checked for a leak? Good luck. Dennis Link to comment Share on other sites More sharing options...
GlennWest Posted December 4, 2015 Author Report Share Posted December 4, 2015 Havn't seen any. Check it out during Christmas days off. Won't get one till then Link to comment Share on other sites More sharing options...
hanabc Posted December 22, 2015 Report Share Posted December 22, 2015 I had this same problem and it is a solenoid that controls the power to the hydraulic pump. Mine had 3 separate solenoid a one for each slide, some newer ones have only one. Hope this helps. If I remember right the cost of the solenoid was about $70.00 Canadian Link to comment Share on other sites More sharing options...
GlennWest Posted December 22, 2015 Author Report Share Posted December 22, 2015 Do you know how to check to see which one? Link to comment Share on other sites More sharing options...
jblscooper Posted December 23, 2015 Report Share Posted December 23, 2015 Glenn, easiest way is locate the pump/valves, have wife engage slide/ feel valves, the one that is buzzing, humming is the one for that room. Jim Link to comment Share on other sites More sharing options...
