jc2 Posted November 17, 2015 Report Share Posted November 17, 2015 I'm seriously considering replacing the Tracvision Domed Roof Sat on our 2004 Newmar Dutch Star with a Winegard Traveler DirecTV HD SK-SWM3 and mounting it on the Travler Mounting Plate. Has anyone done this and if so, do the new screw holes line up with the old ones. Any other issue occur if you have done this mod? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted November 17, 2015 Report Share Posted November 17, 2015 I changed to a Trav'ler from an older Winegard automatic roof dish. You can count on the screw pattern to be different. Therefore the first step after removing the old dish is to seal the old holes. Hopefully the old hole will be under the Trav'ler. The coax cables are easily reusable. Since you are going to a SWM dish, you might have to do something to take the probable two coax cables (front of coach and bedroom) to be a common cable the SWM uses. The biggest challenge is the control cable. I was lucky that the old control cable had more wires than the new control cable. I cut the control cable and spliced wires so I didn't have to run the new control cable thru the roof. If the old control cable has less wires than the new control cable, you will have to run that thru the roof. Hopefully you can use the old control cable to pull the new control cable. A hindrance will be if the old control cable was attached to the coach framework and how well the attachment was. Link to comment Share on other sites More sharing options...
jc2 Posted November 19, 2015 Author Report Share Posted November 19, 2015 Thanks for taking the time to respond along with your suggestions. We have been using a Winegard Carryout G2 on a portable stand and will keep it to use when in cg's where trees tend to rule. Link to comment Share on other sites More sharing options...
Mariner Posted November 20, 2015 Report Share Posted November 20, 2015 What Mark said. We also got rid of the old dome. It's really great to watch HiDef. Link to comment Share on other sites More sharing options...
