Shallow Draft Posted February 10, 2015 Report Share Posted February 10, 2015 With talk of air leaks and such I checked my leveling valve and bags. The valve was leaking badly and the bags look like they could at anytime. It seems the Wabco valve is updated to a Haldex. Has anybody done this and is it a straight forward change or will I have some height adjustment issues as well as possibly connection changes. Link to comment Share on other sites More sharing options...
dascom Posted February 10, 2015 Report Share Posted February 10, 2015 SD: I don't remember what brand KW sold me for mine but it was different. Took a little head scratching but went in with only the expected effort. It was raining at Quartzite, had nothing else to do, and had an entire gaggle of MDT's/HDT's from the Heavy Haulers BoF there should that I get messed up. They won't know you are under the back of the toter, but you open the hood and 10 people will be right over. Link to comment Share on other sites More sharing options...
jkennell Posted February 10, 2015 Report Share Posted February 10, 2015 There may be minor differences that require plugging a line or drilling a new hole in the bracket...but most likely it will drop right in. (Some assm required... ) All the essentials remain the same...measure your frame rail top to a axle reference point (more reliable than the ground which may be rough) Then change the valve. Adjust the valve linkage/bracket if needed until the same measurement is reached. When I changed mine the mechanics were perfect..no adjustment needed. I did have to figure out that my old valve had a "dump lock out" feature (it wouldn't dump if the parking brake was on) that the new one did not. So I had a line to disconnect and plug on the other end. Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 10, 2015 Author Report Share Posted February 10, 2015 There may be minor differences that require plugging a line or drilling a new hole in the bracket...but most likely it will drop right in. (Some assm required... ) All the essentials remain the same...measure your frame rail top to a axle reference point (more reliable than the ground which may be rough) Then change the valve. Adjust the valve linkage/bracket if needed until the same measurement is reached. When I changed mine the mechanics were perfect..no adjustment needed. I did have to figure out that my old valve had a "dump lock out" feature (it wouldn't dump if the parking brake was on) that the new one did not. So I had a line to disconnect and plug on the other end. The Wabco has 3 large lines and a small one I suspect that may be the dump out lock but I am not sure. I assume that there is 1 air line in and 2 out to the bags and I thought the 4th was some thing to do with the air dump process. the new Haldex has 4 ports also but I am not sure of what the functions are until I see it. It was $60.00 the Wabco I found as direct replacement was $145 Link to comment Share on other sites More sharing options...
Nuke-E Posted February 10, 2015 Report Share Posted February 10, 2015 If that's the same upgrade I did right after I got my truck, the mounting bracket will be different. It's a direct swap as far as the air lines go though. There's an updated bracket for the new valve, which I don't think was very expensive. Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 10, 2015 Author Report Share Posted February 10, 2015 If that's the same upgrade I did right after I got my truck, the mounting bracket will be different. It's a direct swap as far as the air lines go though. There's an updated bracket for the new valve, which I don't think was very expensive.That is good to hear. The new Haldex valve comes with a bracket. Link to comment Share on other sites More sharing options...
jkennell Posted February 10, 2015 Report Share Posted February 10, 2015 Large lines are Air Supply, Air out 1, Air out 2. Small line is Dump control from dash. I had a 5th line from the air brake sytem that would lock out the dump when the parking brakes were set. Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 13, 2015 Author Report Share Posted February 13, 2015 OK I am in the process of installing the new bags and level control valve but of course it looks different and I did not measure the height before I removed the old parts. Does anybody have the correct measurement for the distance between the upper and lower airbag mounting plats? is it a number I might find in the resource section? This new valve has 5 large ports [1 in and 4 out] and 1 small port. I will have to make 2 plugs. Link to comment Share on other sites More sharing options...
PEIFamily Posted February 13, 2015 Report Share Posted February 13, 2015 I believe the sweet spot is 7 3/4" from the weld line on your axle to the bottom on the frame. EDIT: Read the following post from: http://www.thetruckersreport.com/truckingindustryforum/volvo-forum/144350-air-ride-height.html finally i went to chicago dealership and have what i wanted....in volvo height adjustment is set by 5 holes in beam under air bags (they are like 2on top, 1 middle,2 bottom ones) . you can't do anything to the vertical rod connected to the air valve couse changing it's lenght is cousing different reaction of the air ride level valve and is not pumping or dumping preassure correctly... i changed both air ride valve and rod to make sure everything is correct for my vin# 150$$ ,then Volvo way of measurment is like this....take a measure of the height of tire which is for my tire if remember right 41 inch, then measure height from the level ground to the bottom of frame (28,25 inch), take half of tire height so 41 / 2 comes to 20,5inch ,next step ---> then take half of tire height minus height form the ground to the frame so... 28,25 - 20,5 is 7,75!!!!!now this number 7,75 is the distance from the center of the drive axle (welding) to the botoom of the frame ,done!! if your number is different then 7,75 you have to make it right Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 14, 2015 Author Report Share Posted February 14, 2015 Thank you PEIFamily that will help greatly when I get air back in the system. this is such a great place for help. Link to comment Share on other sites More sharing options...
PEIFamily Posted February 14, 2015 Report Share Posted February 14, 2015 That's the specs I used last fall and seemed to be the perfect height afterwards.. Now soon as the snow leaves some, I got to finish relocating my valve and adjust it again. Haven't had the truck going in awhile due to the cold. Glad I was able to help. Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 14, 2015 Author Report Share Posted February 14, 2015 Finished this project. everything went as planned other than the new Haldex valve had a couple extra ports to plug. The valve cam with one so I had to build another with airline and a bolt. Height adjustment was a breeze with the 7,75 spec from PEIFamily. thanks again Cost were: $99.00 x2 for bags and $65.00 for the valve and new bracket. Shipping $29.99. Link to comment Share on other sites More sharing options...
hdonlybob Posted February 15, 2015 Report Share Posted February 15, 2015 Of the many spare parts I always carried in my HDT days were a spare main air bag, as well as a cab air bag. After a leveler faiing that fortunately I could fix on the road I also carried an extra one of them too.... Heck, one of my larger compartments was plum full of spare parts ! Cheers,Bob Link to comment Share on other sites More sharing options...
Shallow Draft Posted February 15, 2015 Author Report Share Posted February 15, 2015 If I have an airbag fail I will use a "pneumatic arrestor and a forestland spacer' for a temporary get off the road fix. [vice grip and chunk of wood] Link to comment Share on other sites More sharing options...
PEIFamily Posted February 15, 2015 Report Share Posted February 15, 2015 Shallow Draft, on 15 Feb 2015 - 1:34 PM, said: If I have an airbag fail I will use a "pneumatic arrestor and a forestland spacer' for a temporary get off the road fix. [vice grip and chunk of wood] lol Link to comment Share on other sites More sharing options...
