Ronbo Posted October 14, 2017 Report Share Posted October 14, 2017 I removed my wheel to replace the rear seal as I am converting to oil bath, and I found a rotor cracked. I will purchase a ne one from etrailer.com and see where I can find good bearings and seals. Then I will start on the rest of the brakes. Hopefully I don't have any other that are cracked. http://my3gals.com/photos/img_0808/ Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
MrSeas Posted October 14, 2017 Report Share Posted October 14, 2017 Ron, Is that a “solid” style rotor instead of “ventilated” (slotted)? Why the change from grease to oil bath? Link to comment Share on other sites More sharing options...
Ronbo Posted October 15, 2017 Author Report Share Posted October 15, 2017 Slotted rotor. Oil bath allows better librication and no dry bearings. Easier to check and refill if low. Also easier to see if I have had water infiltration. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
gjhunter01 Posted October 15, 2017 Report Share Posted October 15, 2017 That rotor must have gotten pretty hot one time. That is one benefit of grease packing bearings once a year is it also forces a brake inspection. If your other rotors are OK, then you should check for a sticky brake cylinder or find out why that rotor got so hot. Greg Link to comment Share on other sites More sharing options...
The Quiet Assassin Posted October 15, 2017 Report Share Posted October 15, 2017 Rotors best replaced in pairs FT since September 2007 Safari Trek + M/C http://johncarolandcharro.blogspot.com/ Link to comment Share on other sites More sharing options...
Pat & Pete Posted October 15, 2017 Report Share Posted October 15, 2017 24 minutes ago, The Quiet Assassin said: Rotors best replaced in pairs Why , if both are surfaced the same ? Goes around , comes around . Link to comment Share on other sites More sharing options...
