CO detector
That would be your carbon monoxide detector. If you are running your furnace or other fuel based heater or stove then it may be indicating that you do not have adequate ventilation, or you have a leak/blockage issue going on. Additional information about what might be running in your rig at the time would be helpful.
The other possibility might be that during your normal daily power consumption, your battery may be running low... or be detecting low voltage when your furnace kicks over.
IOW, it could be indicating a number of different scenarios.
As mentioned make sure the power to the CO detector is good and they need replacement in 5 to 8 years. Check the date on yours as they have a defined life span. Greg
Greg & Judy Bahnmiller
Class of 2007
2014 F350
2007 HitchHiker Champagne
CO is an odorless gas that is usually created by some form of combustion and which is the #1 cause of poisoning in the US today. It isn't a case of good/bad but can start to cause damage well before it becomes fatal. It is extremely dangerous. CO detectors do have a limited lifespan and so can & do fail or alarm sporadically. Weak batteries are the #1 cause of false alarms, dirty detectors can also, depending upon which type of alarm yours happens to be. There are also some solvents which can cause false alarms, but it is very important to be sure that the alarm is false as the damage done by exposure to CO can be permanent and cumulative. If in doubt, go out and buy a new one to see what it does to compare as this is a risk that is not to be fooled with.
I suggest that you do some reading about these devices before you go much farther. I suggest "Explain Stuff" to understand the ways that the detectors work and "Safe Links" for an explanation of possible false alarms.
More importantly, make sure your not sleeping in a RV with elevated levels of CO. Many people have died from this & it's nothing to take lightly. As others have said, it could be a faulty CO detector or a slight elevation of CO. I wouldn't sleep in there until I found out what it is.
Todd
Kirk got there just ahead of me so if I repeated anything I apologize.
“…nothing so liberalizes a man and expands the kindly instincts that nature put in him as travel and contact with many kinds of people.” – Mark Twain
Mine started chirping at odd times for no apparent reason. I looked on the label and it stated that it would do just that if it was more than 5 yrs. old. Mine was 6 yrs. so I replaced it. Good to go now with a new reliable unit. Dave.
2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat.
