vacationer Posted May 4, 2023 Report Share Posted May 4, 2023 Any one from ontario on here do there class AR license . Iam wondering what the procedure is on the walk around of truck. Taking my one ton and camper to get the restricted a license . all the drive schools want 1800 dollars for nine hour course. I do no i need first aid kit fire extinguisher and rubber chalks but just not sure of what order they want it all done in. Thanks Lee Quote Link to comment Share on other sites More sharing options...
Pipeman, VE3PJF Posted May 5, 2023 Report Share Posted May 5, 2023 I had a DZ ticket then an AR ticket and now am down to G ticket . Are you sure that you need that AR? The weight restrictions had changed and that's why I dropped down to a D and then to a G and still tow the same 5er with a 1 ton dually. Look up what you can tow with a G. The walk around was doing a circle check as if you are a semi driver, lights, tires etc. Get the drivers hand book for an AR if you have to get it. Another thing I did was follow a semi on a road test to see where they drove for the test and it was always the same route. Good luck Quote Pipeman VE3PJF, 35 year FireFighter, Retired Link to comment Share on other sites More sharing options...
vacationer Posted May 5, 2023 Author Report Share Posted May 5, 2023 Ya even with my dually iam 27000 lbs Quote Link to comment Share on other sites More sharing options...
