youngwillyd Posted January 24, 2018 Report Share Posted January 24, 2018 My 2004 Teton has a white material on both sides of the bedroom floor. It looks like thick plastic maybe. Anyone know what was used? Where I might get it? What I could use instead? I am thinking of using a sheet of 3/4" Advantec flooring to replace the wood. It is for home building and designed to get wet for many days during home construction. Any thoughts? Thanks for any help. Willy 2003 Dodge Ram 3500 4X4 Dually 5.9 CTD 48RE 373 Rear 2004 Teton Experience Frontier Link to comment Share on other sites More sharing options...
GlennWest Posted January 24, 2018 Report Share Posted January 24, 2018 Can't help but curious, where was the leak. Mine is an 03 reason asking 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
youngwillyd Posted January 24, 2018 Author Report Share Posted January 24, 2018 I am pretty certain it started in the small screws at the bottom that hold the angle piece on. From what I can tell it was designed to fail. Putting a metal screw through a piece of metal into the edge of plain OSB with nothing to stop water looks like someone wanted it to fail. 2003 Dodge Ram 3500 4X4 Dually 5.9 CTD 48RE 373 Rear 2004 Teton Experience Frontier Link to comment Share on other sites More sharing options...
GlennWest Posted January 24, 2018 Report Share Posted January 24, 2018 Standard practice industry wide. I do caulk over all the screws though. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
