j2catfish Posted August 6, 2017 Report Share Posted August 6, 2017 Has anyone replaced the flex plastic water drain on the back, outside, of their refrigerator? Mine has broken off near the top and no way I have arms long enough nor skinny enough to reach in there to replace it . Bought the replacement hose from one of the RV salvage shops in Elkhart. Right now I have rigged up a funnel and drain hose but water sometimes gets by my rig. Any help greatly appreciated! (two door side by side refer with top and bottom vents outside) Regards, Catfish '08 Chebbie K3500; '07 Teton Sunrise Experience;Native Texan/Transplanted Tarheel; Retired USMC LDO Link to comment Share on other sites More sharing options...
Kirk W Posted August 6, 2017 Report Share Posted August 6, 2017 You will need to disconnect the electric and gas connections and then slide it forward into the RV to get room to reach up there. If it is a large refrigerator you may need to pull it completely out of its cabinet. It isn't difficult but could be heavy. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
57becky Posted August 6, 2017 Report Share Posted August 6, 2017 On our Norcold, the hose is threaded through a hole on the fridge, but is attached to the drip tray inside the fridge, not a fitting on the outside. Maybe, if yours is the same, you could thread a wire or string through the hole in the fridge down to where you can reach, and connect the new hose and pull it through. Link to comment Share on other sites More sharing options...
SCClockDr Posted August 6, 2017 Report Share Posted August 6, 2017 What Kirk said! If the replacement house is white chuck it in the trash bin. Either use black (UV & heat resistant) or tygon. I used Tyson & formed a dip trap to prevent warm air infiltration. I also slipped a spring over it to prevent kinking where it bends to exit though the lower cover. Link to comment Share on other sites More sharing options...
