GlennWest Posted January 1, 2017 Report Share Posted January 1, 2017 My slide outs work, no binding or anything like that. They are run with a Dewalt pump. It wants to run after slides are in or out. It will stop after some time. It has stopped running and then start again. Thoughts? Link to comment Share on other sites More sharing options...
Tex Bigfoot Posted January 1, 2017 Report Share Posted January 1, 2017 when the same thing happened to me it turned out to be a bad rocker switch .Dirt and grime had built up inside and while the exterior moved fine the actual switch underneath as sticking. Link to comment Share on other sites More sharing options...
GlennWest Posted January 1, 2017 Author Report Share Posted January 1, 2017 You might have it there. It has always continue to operate until all is out or in with or without keeping rocker switch down. Assumed nature of the beast. Link to comment Share on other sites More sharing options...
Tex Bigfoot Posted January 1, 2017 Report Share Posted January 1, 2017 All i have seen you had to hold the sitch manually. This is a safety feature so that the slides can be stopped Mid-travel if needed. Link to comment Share on other sites More sharing options...
GlennWest Posted January 1, 2017 Author Report Share Posted January 1, 2017 Mine never has but it also controls all 3 slides. I also have outside controls at pump. I can open bypass valves and operate each slide individually. I would prefer 3 rocker switches. Link to comment Share on other sites More sharing options...
Tex Bigfoot Posted January 1, 2017 Report Share Posted January 1, 2017 That should be fairly simple mod to do. spilt the hot at the switch and add two more control wires . then add some solenoid valves at the header Link to comment Share on other sites More sharing options...
GlennWest Posted January 1, 2017 Author Report Share Posted January 1, 2017 Downloaded the manual for it. I don't have solenoids. I have a manifold that is why only one rocker switch. Will pick up an new one next week. Link to comment Share on other sites More sharing options...
Flying Finn Posted January 1, 2017 Report Share Posted January 1, 2017 Hi Glen, I have a Teton as well and had the same problem. It turned out to be the inline pump breakers that went bad. I replaced them with an 80 amp re-setable breaker and things are fine. The following year the Trombetta (solenoid) located on the top of the pump motor went bad. Another easy fix. Our Teton has the Lippert hydraulic slide system. If you have Lippert components could have similar parts that need to be replaced. Brad Link to comment Share on other sites More sharing options...
GlennWest Posted January 1, 2017 Author Report Share Posted January 1, 2017 Mine is the Dewalt pump system Link to comment Share on other sites More sharing options...
Tex Bigfoot Posted January 3, 2017 Report Share Posted January 3, 2017 Glenn You probably know this but..................... be sure the switch that you get is a momentary type ( have to hold the switch in the whole time ) and not latching one ( push the switch and it stays in the position until pushed the other way ) Link to comment Share on other sites More sharing options...
