Cathy and Paula Posted October 10, 2016 Report Share Posted October 10, 2016 Can someone tell me why the grate that is on the stairs leading into the bedroom is open to the front bay? All the heat and AC is going down into the front storage compartment. Is there reason for this? There is also open vents under the couch that heat and cool the compartment in the rear. Why??? I do not need to heat or cool my storage compartments and if we are somewhere where it gets really cold the furnace puts off a lot of heat inside the compartment that would keep my tanks warm. Any thoughts please. Thanks Cathy and PaulaUS Air Force Retired2016 Lifestyle LS37CKSL/2016 Ford F350 DRWFulltiming since Aug 09Blog http://www.pclivinthedream.blogspot.com/Blog http://www.pclivinthedream2.blogspot.com/ Link to comment Share on other sites More sharing options...
MrSeas Posted October 10, 2016 Report Share Posted October 10, 2016 So if it's really cold you might want your "storage" compartments to have some heat to keep stuff from freezing. Just a thought.... Link to comment Share on other sites More sharing options...
chirakawa Posted October 10, 2016 Report Share Posted October 10, 2016 Your basement is heated by the furnace in order to protect water and waste tanks. That forced air to the basement must return somehow. The grate is the return air to the furnace. This is why I never leave my outside compartment doors open. Insects which enter through an open compartment door have access to the living area. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Cathy and Paula Posted October 10, 2016 Author Report Share Posted October 10, 2016 Thanks for the info. We are warm weather followers and we are very seldom anywhere where its cold enough to run the furnace. We do put the heat pumps on sometimes but we use the AC the most. So I will close off the vent when we are using the AC. Thanks Cathy and PaulaUS Air Force Retired2016 Lifestyle LS37CKSL/2016 Ford F350 DRWFulltiming since Aug 09Blog http://www.pclivinthedream.blogspot.com/Blog http://www.pclivinthedream2.blogspot.com/ Link to comment Share on other sites More sharing options...
Fulltimer51 Posted October 12, 2016 Report Share Posted October 12, 2016 Magnetic strips from Lowes and others, work well. Cut to fit. Only down side is that they are white. Clear packing tape works well also. I havent noticed any or very little residue left behind. Really cheap too. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
ronmon Posted October 13, 2016 Report Share Posted October 13, 2016 The vent in the steps of a fiver is actually the cold air return for the furnace. The furnace blows hot air into the living quarters and the vent recycles the air back through the furnace. Ron PS: The furnace is in the "basement". it Link to comment Share on other sites More sharing options...
