Adding automatic leveling?
tyates007
I have a 2008 Mobile Suites with hydraulic jacks front and rear. It is currently a 4 point system with 2 switches, one for front and one for rear. I would like to be able to run the jacks independently to raise one side or they other for tire maintenance and such if needed. So 2 questions. Can I change switches to be able to control current system manually? Secondly, if I added a leveling system like Biggoot or Level Up would the existing system be able to be used adding minimal hardware? I plan to call the manufactures of each. Looks to me like Bigfoot has a individual reservoir on each jack where level up is run with a single pump and lines run so this would probably be the easiest to retrofit. Thanks Tom.
