fmracerbob Posted May 5, 2016 Report Share Posted May 5, 2016 Looking for others with the Magnum 8 bag system such as on my 96 Beaver Patriot. Just completed serious trip after having chassis set up done along with new Koni FDS shocks. The ride is terrible, bone jarring over strips, bumps and pot holes. Clearly these shocks are not correct for this chassis. Since I live in California bad roads are unavoidable. Wonder what others are using on their motorhomes with this chassis. 96 BEAVER Patriot 37' total running weight 27,500 pounds. All alignment and ride heights set to factory specifications. Air pressure running 110psi. Bob McCormack Link to comment Share on other sites More sharing options...
docj Posted May 5, 2016 Report Share Posted May 5, 2016 I'm removing this post because you have made this same post on the Beaver Ambassador Forum and have further clarified the situation. The pressure you noted above is your coach's internal air pressure, not the tire pressures. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
