Yarome Posted October 28, 2015 Report Share Posted October 28, 2015 I'm probably looking over something really stupid, but I can't seem to get my Triton outdoor portable heater to fire and I'm really due for a continuous shower (I can only live on Navy showers for sooo long). I've torn it completely apart and given it a good cleaning.. brushed all the contacts, checked for blockage in the propane lines, cleaned the burner, it's getting battery power, propane tank is 3/4 full and getting flow through the regulator. I didn't actually test the pressure from the reg, but I hooked it up to my catalytic heater and it seems to be flowing normally. I didn't think an ignitor would go bad, but I did check continuity on anode and leads and they checked out. The thermocoupler seems fine. It's been in use regularly for the past 3 years without a hiccup. I just can't get it to attempt an ignition. What am I missing here? Link to comment Share on other sites More sharing options...
Kirk W Posted October 29, 2015 Report Share Posted October 29, 2015 From the manual on the internet.......... Troubleshooting Unit will not ignite (There are no audible clicks at start up) 1. Make sure batteries are installed correctly or replace old batteries with new one. 2. Adjust tabs inside of battery compartment to ensure circuit is complete. 3. Make sure there is an adequate supply of water flowing through the system. The appliance requires a minimum of 5 quarts of water per minute flowing through the system at a minimum pressure of 35 psi before it will ignite the burners. 4. Make sure that the water inlet is connected to the correct fitting. The water inlet should be connected to the fitting on the right side closest to the battery compartment. 5. A wire has become disconnected on the inside of the unit. Make sure the gas DRAIN VALVE is OFF. Remove the two knobs from the front of the appliance. Remove 1 screw from the bottom of the water heater going through the tab on the front cover. This is the only screw you need to remove. Make sure that the wire terminals are connected to the top of the battery compartment and all other wires are connected. (Call Technical Support at 1.800.650.2433) 6. Debris may have entered into the water regulator. Reverse the flow of water by connecting the water source to the outlet of the water heater and run water in reverse through the system. This back flushing will remove the debris. Unit will not ignite (There are audible clicks at startup but the burner does not ignite) 1. Make sure propane tank is full and tank is turned on. 2. Make sure there is an adequate supply of water flowing through the system. The appliance requires a minimum of 5 quarts of water per minute flowing through the system at a minimum pressure of 35 psi before it will ignite the burners. 3. Check gas connections for leaks using the soapy water test. If leaks are found make sure the problem is resolved before attempting to ignite the appliance. A gas leak will cause the regulator to reduce the gas flow. When turning on the LP gas tank open the valve very slowly. 4. Remove regulator hose from fitting on appliance and ensure there is no obstruction in the fitting on theappliance Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Yarome Posted October 29, 2015 Author Report Share Posted October 29, 2015 From the manual on the internet.......... Thanks, Kirk. The only one on there I hadn't thought to check was the water supply. My accumulator is set to (edited: 'should be') 40psi, but I'll have to double check that's what it's actually putting out. It hadn't occurred to me that it might be an external issue. Appreciate your time pulling that up for me. Link to comment Share on other sites More sharing options...
Kirk W Posted October 29, 2015 Report Share Posted October 29, 2015 I've never used one of them so the book is the my only knowledge base on the subject. Keep us posted! Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Yarome Posted October 29, 2015 Author Report Share Posted October 29, 2015 Keep us posted! A yep... that was it. I knew I had to be overlooking sumthin small. Accumulator pressure had dropped below 25psi. Even though my pump puts out 40psi I guess the "lax" bladder was killing the pump pressure enough it wouldn't trigger an ignition. Pumped it back up to 40 and wattayaknow!? Fired right up! One more thing to add to my regularly scheduled maintenance list. Thanks again, Kirk! Link to comment Share on other sites More sharing options...
