Towing Toyota stick - older Pickup
LHS61
I'm picking up my 'new to me' Nemar MH in the next few days in Sun City. I have a small '92 Toyota pickup that is in pristine condition with a 5-speed manual transmission. I need to get it set up to for towing and have been given a Roadmaster 5250. Their website says the mounting bracket for this truck is part #1117-1 so I guess the physical side of the hook-up will work. The "specialist" at CW said that the tranny on my pickup "may" not be compatible with my plans due to lubrication issues.
Does anyone have experience and/or comments on these older Toyota 5-speed transmissions ?
I towed my '90 Toyota 4-speed P/U without any problems. What you need to find out is if the '92's tranny gears will lube themselves while being towed. Mine were in the the fluid far enough to splash it around to keep the gears lubed.
Fulltiming since 2010
2000 Dutch Star
2009 Saturn Vue
Myrtle Beach, SC
Good answer. I checked with the REMCO website but unfortunately they only go back to 1996 so didn't find any help there. You might try contacting them as they are sure to know since they have been in business far longer than that and are a great source of information. The fellow at CW was correct in warning you about this as it removes any responsibility on his part. I suspect that a good Toyota mechanic could also tell you if your transmission will be lubed while towing.
is it 4x4??
2000 National RV Sea Breeze 5th wheel 30ft.
So.California
1950 F1 street rod
1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed shortened frame.
1953 chevy 3100 AD for 85 S10 frame
1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc
1970 Baha Bug wihg 2332cc, King coil overs and everything else there is.
1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc.
I tow my '95 Toyota Tacoma 5-speed 4x4 with no problems. Also, the Roadmaster clips were pretty easy to install on mine, as they simply replaced the bolted-on factory tow-hooks. Anyone that can turn a socket wrench can do it.
1999 Newmar Mountain Aire, 640 watts solar
Toyota Tacoma 4x4
Dave,
A good person to ask would be Marlin Crawler they specialize in 4x4's but will know the answer to your 2 wheel drive transmission question.
Mr. Marlin is an innovator in the 4 wheel drive world and has worked with Toyota transmissions and transfer cases for many years. Here is there contact info. http://marlincrawler.com
If you can not tow that transmission 4 down there is a company that sells a drive shaft disconnect for Toyota's. We use these on 4x4 rock crawlers for flat towing and doing front wheel burns. Not sure it will work for a 2 wheel drive so call before before purchasing.
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=90&category_id=51&option=com_virtuemart&Itemid=53
