Charles Skinner Posted May 21, 2015 Report Share Posted May 21, 2015 When we travel, we stop often to rest. (old folks) When we stop, I usually feel around the hub area to see if any extra heat is there. If I was about to have bearing problems, do you think I would be able to feel heat coming from inside? C. S. Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted May 21, 2015 Report Share Posted May 21, 2015 I think if there were a problem you could feel it, I have the TST tire monitors and they tell air temp. which is a good indication of a problem. OR you can probably do better with a inexpensive laser temp gun. 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
kathydavidb Posted May 21, 2015 Report Share Posted May 21, 2015 X2 on getting a temp. gun. Just point it at each wheel and get your temps. If one is hotter than the others it may indicate a problem. Dave. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat. Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted May 22, 2015 Report Share Posted May 22, 2015 I just got back from a long trip and monitored the tire with the TST monitor and most of the trip was cool but on the way back in Needles the temps were about 100 degrees and I stop to take some pictures and found two of the tires very hot. The tires facing the sunny side and all in general increased in temp quite a bit and when I got rolling the all better leveled out the sunny side is always a bit hotter but not the extreme I go while sitting on the hot pavement. 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
Devilishjim Posted May 22, 2015 Report Share Posted May 22, 2015 In hot weather we try to get our driving in during the cool of the mornings, slower speeds helps tire temps and frequent rest stops for tires to cool down and are usually stopped by 2 in the afternoon. Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
rdickinson Posted May 22, 2015 Report Share Posted May 22, 2015 My rig has hub covers so heat isn't as evident from the outside so I have a Ratheon IR heat gun. To get temps on the right side, I go to the left side and shoot the back of the drums from underneath the trailer. You can see the red dot of the laser readily as it is in the shade. I find temps in the 100 degrees f. What I'm looking for is a spike in the temp in 1 or more wheels. If you are interested, I can provide the model of IR gun. Link to comment Share on other sites More sharing options...
skp51443 Posted May 23, 2015 Report Share Posted May 23, 2015 I picked up an inexpensive IR gun from Amazon, it seems to do a good job of checking temps. The laser dot also works well to exercise the neighbor's cat. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
