dkgood Posted January 30, 2015 Report Share Posted January 30, 2015 Has anyone had to replace drain tube on back of fridge if so did you do it yourself or have to have it done. Any info appreciated. Link to comment Share on other sites More sharing options...
skp51443 Posted January 30, 2015 Report Share Posted January 30, 2015 If it isn't cracked and leaking or the end ripped off it may just need cleaned, are you sure you need a new one? How hard they are to replace varies by fridge, some you can reach through the rear access plate, some you can slide the fridge forward a bit and still reach from the back and some you really need to slide all the way out of the cabinet to get to the hose to fridge connection. Check your owner's manual or download a parts manual to see what you are facing. Any of these are easy enough to do if you have two folks that can lift the fridge and a sturdy stand of about the right height to rest it on if you have to pull it out of the cabinet. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
Big Greg Posted January 31, 2015 Report Share Posted January 31, 2015 What brand of fridge do you have? I replaced one on our 8cf Dometic as the tube was brittle and broke several times. You can pop the connection point out from the inside of the fridge to replace the tube. Two years latter the fridge died so we replaced it with a residential fridge. Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
