Brad NSW Posted March 19, 2018 Report Share Posted March 19, 2018 If anyone has done this install, I'd like some advice. Problem: Brake controller sends signal to my trailer if I manually push the controller button. However, when I push the brake pedal, I get no signal going to the trailer through the Jackalopee, although the brake lights work. What I'm looking for is where/how did you connect into truck brake system to the Hopkins? Heavy Metal - It's your old truck. If you installed the Hopkins some insights on where that connection is? 2010 Freightliner, DD15 Eaton Ultrashift, 2015 New Horizons 5th Wheel. Occupants - Dena/Brad/Hershey BLOG LINK Link to comment Share on other sites More sharing options...
