rynosback Posted August 25, 2017 Report Share Posted August 25, 2017 I have been thinking. If I took a mini USB to USB 2 or 3 cable and connected the Mobley to a 5GHz router. Would I have faster speeds? I'm not trying to hook up more the the 5 device limit. But improve it. The Mobley can download up to 100 Mbps, so it got me thinking that maybe the weak link is the wireless connection to the devices that I have on the Mobley. As the Mobley only has 802.11 b/g/n and not 2.4 or 5 Ghz. Thanks for the feedback and thoughts. LTE 700/850/1700/1900HSPA 850/1900Download speeds up to 100 MbpsWi-Fi 802.11 b/g/nConnect up to 5 Wi-Fi devices 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Biker56 Posted August 25, 2017 Report Share Posted August 25, 2017 The weakest link is whatever tower the Mobley is working off of. You will never see a 100Mbps. In the 6 different states over the last 6 months I have been in. Fastest has been 22.40 and slowest 2.40Mbps I just ran a test where I am now and got a 11.21Mbps My Sprint iPhone got 36.96Mbps Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 26, 2017 Report Share Posted August 26, 2017 I've found that simply hanging the Mobley out the window more than doubles the speed . That's with no antenna . Mobley only . Goes around , comes around . Link to comment Share on other sites More sharing options...
jerryneal Posted August 27, 2017 Report Share Posted August 27, 2017 7 hours ago, Pat & Pete said: I've found that simply hanging the Mobley out the window more than doubles the speed . That's with no antenna . Mobley only . X2 with Pate and Pete. When we get to a new location, we move the Mobley from window to window for the best tower location while monitoring the signal level from the wifi manager. We too leave it hanging in the window and sometimes get 2 times or greater speeds. Jerry and Joan 2014 Ford F350 with 6.7 turbo, TrailerSaver 2014 40' Heartland Gateway Fifth wheel iLoveRVlife.com Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 27, 2017 Report Share Posted August 27, 2017 34 minutes ago, jerryneal said: X2 with Pate and Pete. When we get to a new location, we move the Mobley from window to window for the best tower location while monitoring the signal level from the wifi manager. We too leave it hanging in the window and sometimes get 2 times or greater speeds. Currently the Mobley is actually outside the window . Of course we'll 'let it in' before we retire for the night . Goes around , comes around . Link to comment Share on other sites More sharing options...
rynosback Posted August 27, 2017 Author Report Share Posted August 27, 2017 11 hours ago, Pat & Pete said: I've found that simply hanging the Mobley out the window more than doubles the speed . That's with no antenna . Mobley only . I put mine at a window inside with the label side out. I check the signal strength at many directions before I choose one. 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
