GlennWest Posted November 7, 2022 Report Share Posted November 7, 2022 (edited) Found vent on roof. Went straight down to basement area close to door. Great. So drilled hole and ran solar pv cable. Now I find out this is a vent and drain line for washing machine. Drain line with vent tied into it.DW is concerned about this. I don't see any liquid or bleach strong enough to damage it. It rains on it every time it rains. Our new quick spin out washer forces some water up vent line. I tried into bottom of ninety fitting. Think this be good or DW got it right. Edited November 7, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
palmeris Posted November 7, 2022 Report Share Posted November 7, 2022 Is the wire wet rated? On the side of it should have printing indicating what it is and the rating. Wet rated, UV / sunlight resistant, direct burial, oil resistant, etc. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted November 7, 2022 Author Report Share Posted November 7, 2022 (edited) It is actual pv wire. 600 v rating. Direct burial. Wet or dry. Photovoltaic wire. Yes I looked it up and stated submersible. Showed it to DW and she calmed down now. I didn't realize it was a drain to. Went straight up to roof so I taped in. When she stayed washing I had a leak. Just needed more silicon I made mistake of telling her. Edited November 8, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 9, 2022 Author Report Share Posted November 9, 2022 Loosing this battle. Will have no rest with DW until I change it. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 10, 2022 Author Report Share Posted November 10, 2022 I pulled cable back up to roof. Cut hole in wall in bathroom. Actually a square hole. Exposing the vent line. Drilled hole in pipe vent and feed lines back down and DW fished them in at hole in pipe. Then ran fish tape up from storage area to bathroom where hole cut. Pulled into storage while DW kept it untangled. Put panel back up and finished it with molding. Just looks like it needs a picture in it. Lol. DW happy now and I am out of doghouse. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
