Daveh56 Posted August 10, 2018 Report Share Posted August 10, 2018 Hello, Just thought I would share some information on Sleeper/Truck to RV conversion requirements of New York State. Also info on the R endorsement 30 day permit. 15 CRR-NY 4.2 states the following: "15 CRR-NY 4.2 15 CRR-NY 4.2 4.2 Prohibition against use of learners' permits on certain highways. No person holding a learner's permit shall operate or drive a motor vehicle on any street or highway as set forth in this section. (a) Restricted highways in New York City. (1) Any street located within a park. (2) All bridges and tunnels under the jurisdiction of the Triborough Bridge and Tunnel Authority. (b) Restricted highways in Westchester County. (1) Hutchinson River Parkway. (2) Cross County Parkway. (3) Saw Mill River Parkway. (4) Taconic State Parkway. CROSS REFERENCES: Drivers' licenses and learners' permits, Vehicle and Traffic Law § 501. RESEARCH REFERENCES AND PRACTICE AIDS: 7A Am Jur 2d, Automobile and Highway Traffic §§ 96---103, 108. 7 Am Jur 2d, Automobiles and Other Vehicles § 82. 15 CRR-NY 4.2 Current through April 30, 2018" And: 15 CRR-NY 106.3 106.3 Passenger registration. <snipped for brevity> (d) Modified van or passenger van. A van with at least one seat or seat fittings or camping equipment behind the driver and at least one rear side window. This equipment must be permanently installed. Camping equipment means that a bed, stove or refrigerator must always be in the vehicle. Any use of the van without this equipment requires the vehicle to be registered as a commercial vehicle. (e) Motor home. A self-propelled vehicle designed as a travelling place of abode. To qualify as a motor home, a vehicle must have at least four of the following facilities: (1) cooking with an on-board power source; (2) a gas or electric refrigerator; (3) a toilet with exterior evacuation; (4) heating or air conditioning or both from an on-board power source separate from the vehicle engine; (5) a potable water supply system including a faucet, sink and a water tank with an exterior service connection; and (6) a 110-125 volt power supply separate from the vehicle engine. (f) Specialized vehicle. A motor vehicle including a van or truck with a gross weight under seven thousand pounds, regardless of seating or window arrangements, which is equipped or modified with a powered lift or ramp or containing any other physical device or alteration for the purpose of accommodating a wheelchair or permitting access of a wheelchair-bound person, and which is intended to be used for the transportation of a disabled person or persons confined to a wheelchair. (g) Station wagon. An enclosed vehicle with folding seats, rear side windows and no trunk, usable for both passenger and delivery purposes. 15 CRR-NY 106.3 Current through April 30, 2018 So you need items 1,2,4 and 6 which can be fulfilled with a Frame rail mounted APU Microwave Refrigerator and A/C you will still have room for your sleeping bunk too. Yes you can drive your "Motor home" with the R permit without having someone with you with the proper license, except for those highways indicated above. Good luck and Happy Trails, Dave All the above can be found here: https://govt.westlaw.com/nycrr/Browse/Home/NewYork/NewYorkCodesRulesandRegulations?guid=I51dc5680ac3d11dd9f72c1eb90efe723&originationContext=documenttoc&transitionType=Default&contextData=(sc.Default) Link to comment Share on other sites More sharing options...
