kountryguy1 Posted August 22, 2016 Report Share Posted August 22, 2016 I have a 99 Newmar Star fifth wheel with a, for lack of a better way to describe it, carpeted ceiling. I had a small leak around my TV antenna that stained the ceiling material. Does anyone have any suggestions on how to remove those stains. Thanks for any suggestions. Link to comment Share on other sites More sharing options...
TreyandSusan Posted August 22, 2016 Report Share Posted August 22, 2016 We have a 2002 Travel Supreme with carpet ceiling (off-white). I used Clorox with Bleach kitchen and bathroom cleaner and a soft toothbrush. Worked like a charm. I tested it on the ceiling inside a cabinet first to make sure it didn't discolor. I think a diluted bleach solution might work also but didn't test it since Plan A worked so well. Good luck! ~ SusanYou fixed the leak first, right? Link to comment Share on other sites More sharing options...
kountryguy1 Posted August 22, 2016 Author Report Share Posted August 22, 2016 Yes, I do believe I have the leak fixed! Thanks for the suggestion. I will give it a try. Link to comment Share on other sites More sharing options...
SIBERNUT Posted August 22, 2016 Report Share Posted August 22, 2016 FYI, there are RV places that will put a fan in your door, and pressurize the coach with a couple of pounds. They then spray soapy water anywhere there could be a leak, and you KNOW you got it. Link to comment Share on other sites More sharing options...
Brook34 Posted September 12, 2016 Report Share Posted September 12, 2016 Having sold carpet at one time, I learned from the mfg. rep that rubbing alcohol works great on carpet stains, especially nylon carpet. Just pour a little onto a clean rag and rub out the stain. Works great and never had any damage to the carpets from it. Link to comment Share on other sites More sharing options...
