Greg112 Posted May 20, 2016 Report Share Posted May 20, 2016 Do the inductive cradles only work in an active (with amplifier) mode? Going through the basements I found my old (5 years) amplifier/antenna which I haven't been where its needed for some time. Since we're in an area with adequate but not great coverage (4g LTE) I thought I'd see what I could see. Now I knew the amp wouldn't work as its non-LTE 850/1900. But the antenna has 700-2500 coverage and is mode independent so I hooked it up to the cradle, inserted phone and saw no difference in measured dbm signal strength. Were it a direct connection even without the amp I'd expect to see improvement but I don't know about the cradle - it may require a boost to work??? Is there a way to force my phone into a CDMA mode and would that change the band to 850/1900 from what I suspect is 700 (Verizon). Samsung Galaxy s4 only shows a LTE/CDMA. Link to comment Share on other sites More sharing options...
Max Signal Posted May 20, 2016 Report Share Posted May 20, 2016 Do the inductive cradles only work in an active (with amplifier) mode? Going through the basements I found my old (5 years) amplifier/antenna which I haven't been where its needed for some time. Since we're in an area with adequate but not great coverage (4g LTE) I thought I'd see what I could see. Now I knew the amp wouldn't work as its non-LTE 850/1900. But the antenna has 700-2500 coverage and is mode independent so I hooked it up to the cradle, inserted phone and saw no difference in measured dbm signal strength. Were it a direct connection even without the amp I'd expect to see improvement but I don't know about the cradle - it may require a boost to work??? Is there a way to force my phone into a CDMA mode and would that change the band to 850/1900 from what I suspect is 700 (Verizon). Samsung Galaxy s4 only shows a LTE/CDMA. Induction cradles only work with amplifiers Keeping You ConnectedProud Commercial Member #129 http://www.maximumsignal.net/ Link to comment Share on other sites More sharing options...
Greg112 Posted May 21, 2016 Author Report Share Posted May 21, 2016 Thanks Gord, looks like I'll be visiting your web site for an amplifier replacement before I get somewhere I really need help with getting connected. Link to comment Share on other sites More sharing options...
