zen Posted May 26, 2015 Report Share Posted May 26, 2015 I need some help with my 2000 Fleetwood Discovery 5.9 cummins diesel. I recently bled the water out of the fuel line at the bleeder in front of the water heater on the curb side. I thought I tightened it but evidently not. I went to move it and it started fine and then stalled shortly after. I tightened the bleeder all the way and purged the fuel system three or four times but it will not start. Looking at the manual it says further bleeding may be called for and to loosen the banjo fitting on the fuel pump inlet. The problem is that that fitting is behind the air compressor and I can't get to it. Any advice or help would be greatly appreciated. Link to comment Share on other sites More sharing options...
