What's the common name for the rain gutter trim?
TxCowboy
I was inspecting the RV this morning and noted that a six foot length of what I call a "rain gutter" has failed. Unfortunately, I can't seem to find a replacement item called "rain gutter".
So what is the name of the trim piece that runs along the top edge of the walls and rear of the RV and acts as a channel to divert the water from the roof to the four corners of the RV?
Is this what you're talking about? http://www.rvstoredirect.com/standard-drip-rail-channel-replacement-part-4937156-mini-gutter-p-4320.html
Went out and took a good look. It appears to be some sort of slide-in rubberized stripping that fits into top and bottom groves and is held in place by a couple of screws at the front and rear. This permits water to run into the drip rail that you see and then flows to the corners of the rv
Hmm, I cannot attach a picture from my computer. Sorry!
This unit is a Heartland Greystone 2011 32RL, if that helps.
http://www.rvstoredirect.com/gutter-extension-pack-4942123-p-4328.html
The link to this website shows a downspout attachment. The item I need is the rubberized seal / water diverter at the top of the photo and held in place by the screw. This seal / water diverter run along the entire top of both sides of the RV.
RV Cable Grip
RV Cable Grip
RV Air.
