Gregoreo Posted March 22, 2018 Report Share Posted March 22, 2018 I bought a preowned Toad, a 2001 chevy blazer with all the necessary towing equiptment feom a former rver. I hooked the blueox towbar, 7 pin electrical harness and the safety and brake away cables to my thor ace class a. The blazer also has a vacuum port next to the break away clip on the front end that a blue air line is supposed to go to my rv. I have no connection on my rv for that vacuum line/air hose to connect to. Under the hood of the blazer is a vacuum brake cylinder and equiptment for the assisted brakes. Any recommendations on what i need to my coach to make this work? Link to comment Share on other sites More sharing options...
Kirk W Posted March 22, 2018 Report Share Posted March 22, 2018 2 hours ago, Gregoreo said: The blazer also has a vacuum port next to the break away clip on the front end that a blue air line is supposed to go to my rv. I would bet that what you have is a connection for air pressure from an air brake system of a diesel pusher rig. If I am right, your Ace won't have anywhere to connect it since gas chassis do not have an air brake system. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jcussen Posted April 1, 2018 Report Share Posted April 1, 2018 As Kirk said, but some manufacturers of toad brakes [eg M&G] make a system that converts hyd pressure from your coach brakes to an air pressure signal to your toad, Of course you will have to install a small air compressor in your coach. https://m-gengineering.com/ Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
