Saab guy Posted March 23, 2016 Report Share Posted March 23, 2016 I went to check on my 2002 HR endeavor DP 40 dst saw a very small amount of coolant in drip pan less than half a cup. I have never seen any coolant loss before and have only owned this unit for about 8 months has been in storage for 4 months. I did not see any coolant in drip pan in December when I was there last Thanks in advance Bill Link to comment Share on other sites More sharing options...
jtown Posted April 9, 2016 Report Share Posted April 9, 2016 Might check the hose clamps. I had one fail on my Ford V10 engine. They used the type that just squeeze really tight and one of them corroded and broke while I was parked in New Orleans. When I started the engine, coolant came flowing down the side of the engine. Link to comment Share on other sites More sharing options...
Kirk W Posted April 9, 2016 Report Share Posted April 9, 2016 I would definitely make a close inspection before starting the engine as the coolant has no pressure while cold but it does once the engine is warmed up and running. If something is seeping a bit now, it may well be a major problem if driven. With a coach that is 14 years old it could be time for new hoses and/or clamps or possibly something else. If you don't find any source, observe closely after you start the engine to make sure it doesn't suddenly get worse. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
