Topics
Posts
Anyone else here use the AirSafe 25K with the Holland head, not the new style head ? I need a favor from anyone that has one. I need a photo of the hitch head and what keeps the head tilted towards the rv. Mine is missing this part and AirSafe doesn't have parts for the Holland heads since they are no longer made, they use one that looks like a Reese but the frame & airbags are the same. Im using a rubber bungee now and would like to get this fixed even if I have to make. Thanks
I'm thinking you probably mean an incinerating toilet, as burning it?
Cost of an aerobic system for us will be right at $10k. site dug up and the system uses an air pump at 81 watts per hour. Everyone also says added cost it have pumped out every so many years. anaerobic not allowed and would not work in our clay. We have no interest dealing with compost unit. Now emptying trash in a trash can we can deal with. All I have read on this unit it uses about what a modern fridge uses power wise. Or it can use propane and 12v for controls. Incenerating units run 2500 to 4000 dollars. Plans are to mostly on solar with electric service for backup. Huntsville is cool with using a drum for gray water. All I have read on these units are positive. Liners man cost. Just two of us so usage not high so that cost should not be bad. Any thoughts from you guys?
