Gary Sonmore Posted June 28, 2023 Report Share Posted June 28, 2023 $29,900.00 LOW Miles - 35,800 Entire RV in good condition Lots of updates from original Updated Audio and HD TV systems including GPS Newer tires, brand new engine battery. Two Deep Cell House batteries. New oil and all fluids full. NO LEAKS. New front brake pads, rear brakes newer Dash A/C just serviced. 2 rooftop A/C Units in good working order All solid oak cabinets (not cheap veneer or plastic) Amenities RV Details Year - 2007 Manufacturer - Four Winds RV (by THOR) Make - Hurricane Model - 30Q Class - Class A Motor Home Sleeps - 5 Total Number of Beds - 3 Fresh water tank - 100.0 gal Length - 31.5 ft Height - 12.0 ft Drivable Features Transmission – Automatic - Allison Cruise control - Yes Engine - Ford TritonV10 Seatbelts - 6 Fuel type - Gas Fuel capacity - 70 gal Fuel consumption - 8.0 mpg Electrical service – 20, 30 or 50 amp Cummins Electrical Generator Power steering - Yes Gross weight - 12,000 lbs Dry weight - 12,000 lbs In good working order: Rooftop A/C Units Heating system (LP) Electrical Generator All kitchen appliances (very little use) All plumbing All electrical All windows/doors/vents Ground Levelers Exterior lights (except rear backup lights don’t work) Year: 2007Manufacturer: Four WindsModel: HurricaneModel #: 30QMiles: 35,800Engine: Triton V10Transmission: AutomaticChassis: FordSleeps: 5Leveling Jacks: Automatic Leveling JacksExterior Camera: No A/C: 2Heating: CentralGenerator: Cummins Onan Awning: 15 Ft AwningGenerator Hours: 207Electric Step: YesTV: 28” HDTV, 20” HDTV rearDining Style: Dinette BoothSofa/Couch: Couch BedBedroom: Double custom springRefrigerator: Nor-ColdStereo: Kenwood with GPS, BluetoothMicrowave: SylvaniaWindows: Single Pane WindowFuel Type: GasStove: 1 Burner: 3Electrical Svc: 20, 30 or 50 AMPBatteries: 1 Engine 2 House (Deep cell)LP Gas: 18.9 GallonsWater Heater: 6 Gallons SPECIFICATIONS and DIMENSIONS General RV Category: Motorized RV Type: Class A Motorhome Body Features Chassis Construction Steel frame Roof Material One-piece rubber Side Wall Material Fiberglass with aluminum framing Slideouts 0 Bath Layout Sink, toilet, shower Chassis Chassis Ford F53 Optional Chassis Workhorse W16 Layout Front Engine, RWD Brakes 4-wheel disc with ABS Tire Size 225/70R19.5 Dimensions and Weights Wheelbase (in) 190 Overall Length (ft/in) 31' 5" Overall Height (ft/in) 11' 7" Overall Width (in) 100 Interior Height (ft/in) 6' 8" Gross Vehicle Wt Rating (GVWR) 15700 Unloaded Curb Weight (lb) 13250 Front Gross Axle Wt Rating (lb) 6000 Rear Gross Axle Wt Rating (lb) 11000 HVAC Furnace BTU 35000 A/C BTU 13500 Powertrain Fuel Type Gasoline Engine Manufacturer/Model Ford Triton Type of Engine 6.8L V10 Horsepower @ RPM 362 @ 4750 Torque @ RPM 457 @ 3250 Alternator Amps 130 Transmission 5-sp. TorqShift Auto Rear Axle Ratio 5.38 Tank Capacities Fuel Capacity (gal) 75 LP Gas (gal) 20 Water Heater (gal) 6 Fresh Water (gal) 52 Gray Water (gal) 44 Black Water (gal) 26 Towing Tow Capacity Standard 10300 Tow Hitch Rating 5000 https://youtu.be/vihBEwGnK2s 2007 30Q (NOT ACTUAL UNIT) Quote Link to comment Share on other sites More sharing options...
