StarlifterFE Posted March 17, 2018 Report Share Posted March 17, 2018 Is there a way to re-calibrate the GPS in the dish System? Barry StarlifterFERetired USAF C-141 Flight EnginnerFull-Timers2005 Holiday Rambler Ambasador 2010 Honda CR-V Link to comment Share on other sites More sharing options...
57becky Posted March 20, 2018 Report Share Posted March 20, 2018 We've had our Trav'ler Dish system for over five years, fulltime, and have never had a need to do any calibration, assuming this can be done or is needed. What is the problem you are having that would necessitate a recalibration? Link to comment Share on other sites More sharing options...
Biker56 Posted March 20, 2018 Report Share Posted March 20, 2018 1. Press [POWER] and hold for 2 seconds to turn “ON” the TRAV’LER Interface Box. Wait until the Interface Box fnishes “connecting to antenna”. * The TRAV’LER may enter the “Search Routine” after 10 seconds this is normal (See NOTE Below). 2. Press [ENTER] and hold for 2 seconds or until the unit displays “Enter User Menu”. Press [SELECT] to move the asterisk to “Yes”. Press [ENTER]. 3. Press [SELECT] to move the asterisk to INSTALLATION. 4. Press [ENTER]. You will be asked to provide a code to enter the Installation Menu. 5. Press [ENTER] 4 times to enter code 0000. 6. Press [SELECT] to move “ * ” to “Calibrate EL”. 7. Press [ENTER]. 8. Press [SELECT] to move “ * ” to YES. 9. Press [ENTER] to start the elevation calibration procedure. The LCD should now display “ Cali brate EL In Progress ...”. 10. After a few moments the IDU LCD will display “On EL Hard Stop?- Yes *No”. Visually examine the antenna to verify that the antenna is against the Hard Stop. The antenna will be pointing as far up as it can go, this is the Hard Stop. 11. Press [SELECT] once to move asterisk to “Yes” if antenna is on the Hard Stop. 12. Press [ENTER] and the LCD will display “Calibrate EL Success”. 13. You may now stow the antenna. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
StarlifterFE Posted March 20, 2018 Author Report Share Posted March 20, 2018 8 hours ago, 57becky said: We've had our Trav'ler Dish system for over five years, fulltime, and have never had a need to do any calibration, assuming this can be done or is needed. What is the problem you are having that would necessitate a recalibration? I don't think the skew is working properly. After it finds the satellites and peaks the signal for 99 & 103 are low. If I manually move the skew just an 1/2 inch or so all the transponder signals go up into the 90's. StarlifterFERetired USAF C-141 Flight EnginnerFull-Timers2005 Holiday Rambler Ambasador 2010 Honda CR-V Link to comment Share on other sites More sharing options...
StarlifterFE Posted March 20, 2018 Author Report Share Posted March 20, 2018 2 hours ago, Biker56 said: 1. Press [POWER] and hold for 2 seconds to turn “ON” the TRAV’LER Interface Box. Wait until the Interface Box fnishes “connecting to antenna”. * The TRAV’LER may enter the “Search Routine” after 10 seconds this is normal (See NOTE Below). 2. Press [ENTER] and hold for 2 seconds or until the unit displays “Enter User Menu”. Press [SELECT] to move the asterisk to “Yes”. Press [ENTER]. 3. Press [SELECT] to move the asterisk to INSTALLATION. 4. Press [ENTER]. You will be asked to provide a code to enter the Installation Menu. 5. Press [ENTER] 4 times to enter code 0000. 6. Press [SELECT] to move “ * ” to “Calibrate EL”. 7. Press [ENTER]. 8. Press [SELECT] to move “ * ” to YES. 9. Press [ENTER] to start the elevation calibration procedure. The LCD should now display “ Cali brate EL In Progress ...”. 10. After a few moments the IDU LCD will display “On EL Hard Stop?- Yes *No”. Visually examine the antenna to verify that the antenna is against the Hard Stop. The antenna will be pointing as far up as it can go, this is the Hard Stop. 11. Press [SELECT] once to move asterisk to “Yes” if antenna is on the Hard Stop. 12. Press [ENTER] and the LCD will display “Calibrate EL Success”. 13. You may now stow the antenna. Thanks Biker. I'll give it a shot. B StarlifterFERetired USAF C-141 Flight EnginnerFull-Timers2005 Holiday Rambler Ambasador 2010 Honda CR-V Link to comment Share on other sites More sharing options...
