Posted (edited)
My truck just threw a "ACM" error code. I did some research and found this article...
https://static.nhtsa.gov/odi/tsbs/2022/MC-10208618-0001.pdf
The truck is hard to start...like low batteries. Struggles to kick the engine over. I'll check and clean the connections tomorrow.
The diagnostic readout does not contain error codes, which could be a good sign that it is not too bad.
Any thoughts on this fix would be appreciated.
Edited by trimster
Robert & Lisa
'14 Keystone Fuzion 315 38' 5er
2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours)
2013 Smart Fortwo Passion 'K-9'
2011 CanAm Spyder RT Limited (Ours)
We are both USAF vets.
Posted
I replaced the batteries. Starts great. I took it for a test run. Once home, I turned the engine off and then back on. The error cleared. Whoohoo!
Love it when a plan works.
Robert & Lisa
Posted
 Awesome. Thanks for updating us. I too like self clearing codes. Had my DEF quality sensor throw a code. Replaced sensor, test drove for 20 minutes, shut down for a couple minutes, then upon restart, no code.👍
I'm a work'n on it.
