Head Lights?
I have a 2000 Suncruser. I have a low beam light not working but the high beams all work! I tried to replace the low beam light, but it also will not come on. Is there a fuse?
Still seeing Places we have never seen before and others that we thought we would never see again!
homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com)
George Hartshorn | Facebook
 Do you have a volt meter.  I know I asked before. But I cannot remember.
  Probably not a fuse problem. With a dc volt meter you could test and see if there is power to the connector.
  There could just be a connector problem. That is the plug end that goes on the light it self.
  Testing will give us directions to go to fix the problem.
It does and you need to visit this link for a fuse chart. A fuse would take out at least 2 headlights, however.
https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=6299&languageCode=en&countryCode=USA&Uid=G1963503&ProcUid=G1963504&userMarket=USA&div=f&vFilteringEnabled=False&buildtype=web
Edited by Kirk W
   I am thinking since the other headlights work, the fuse should not be the problem.
   I would check for voltage at the connector first. I have a connector fit on the bulb and be tight. But possibly the low beam power wire connector is not making contact on the spade connector on the head light.
  Since the high beam is working, that power and ground is good. They normally use the same ground. So if there is power on the low beam pin, then it is apparently not making contact with the spade terminal. The female spade terminal in the plug connector could just need to be reshaped to make good contact.
It should not have a fuse for just one headlight, it will be for both; but usually headlights have an auto-reset breaker in the U.S.A.
Thanks Guys, it turned out to be a miss placed fuse under the dash! I have no clue but it's working now....
  • 3 weeks later...
Giraffe G4.
