Class 8 conversion for fifth wheel
Mikomi1
 Share
It also depends on what you final goal is. If all you want to do is haul a 5th wheel RV, you only need to do a few things to a class 8 truck. Add a Jackaloppe for the wiring converter. Add a brake controller like a Tuson Direct Link. Add fenders to protect the RV, either move the commercial hitch towards the rear of the truck so you can turn the trailer without hitting the truck or better yet replace the commercial big hitch with an RV style air ride hitch and mount it at the rear between the frame rails. This part may be the hardest as you typically have to add a little bit of frame to do it.
Anything else you do is just extra like making a hauler bed, carrying a smart car, adding extra water tanks, adding a generator, adding storage compartments, etc....
For me it was worth the bother to build the bed and so on to convert a HDT.  At least at that time which was around 18 years ago.  Today it would be more of a challenge than I  might be ready for and I doubt I would try it. Depending on what you want it can be a project and the lifting and work involved is significant.  At least for me it was.  I carry a Subaru length wise so the frame is extended and it has 100 gallon water and waste tanks along with toolboxes.
 Share
