Scocciante Posted December 4, 2022 Report Share Posted December 4, 2022 2020 Solitude Front Piston leaking. Lippert does not sell a kit to replace the seals. With that great news Is there any after market kits out there. I have no bolts 1 Big Nut on the bottom Spanner type cap on top 4 hole Quote Link to comment Share on other sites More sharing options...
rickeieio Posted December 4, 2022 Report Share Posted December 4, 2022 I would try to get a part number for that seal, which is unlikely. Or, take the cylinder off and take it to a hydraulics shop. Odds are good it's a common seal. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Wrknrvr Posted December 4, 2022 Report Share Posted December 4, 2022 Can you see any scratch marks on the shaft. If you do, then the repair shop is likely needed. Is the shaft bent? The repair shop is needed at that point also. Or new jack. Before you do the repair shop idea. And you see no physical problems on the shaft. Search the net about Lippert suggesting to put Caterpillar hydraulic additive into the system. Back several years ago Lippert had a problem with the jacks leaking while the rv was sitting still. It was a internal seal problem. You can find the Caterpillar oil additive at a Caterpillar dealership. Probably on line also. As for fixing the external leak with the additive needs some questions asked. The additive would be a simple fix. Quote Link to comment Share on other sites More sharing options...
rpsinc Posted December 10, 2022 Report Share Posted December 10, 2022 On 12/4/2022 at 7:44 AM, Wrknrvr said: Caterpillar hydraulic additive into the system I used Lucas fork oil for motorcycles. Solved a leak AND caused the whole system to operate better. Will do that from now on. Quote Marcel Link to comment Share on other sites More sharing options...
