lifeisgood1234 Posted November 11, 2022 Report Share Posted November 11, 2022 We have a Jetpack Mifi 8800 that I think is wearing out after much use. The resolution on the TV is often blurry now even with an excellent signal. Up until a month or so ago all was fine. I bought a Verizon new in box identical replacement on Ebay. I'm wondering if I can simply switch sim cards. I'm not very tech savvy. I got this unlimited plan just before they discounted it and my biggest fear is I'll screw something up and loose the plan. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 11, 2022 Report Share Posted November 11, 2022 Switching the SIM card will work. No need to contact VZW. I doubt the 8800 is at fault though, since a digital signal is pretty much go or no go as long as you have a good signal and decent speeds. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
lifeisgood1234 Posted November 11, 2022 Author Report Share Posted November 11, 2022 Any thoughts what the issue could be? We are home and aren't moving around with it. It was acting up when we traveled with it recently but that involves a lot of variables so didn't think much of it. Quote Link to comment Share on other sites More sharing options...
docj Posted November 11, 2022 Report Share Posted November 11, 2022 29 minutes ago, lifeisgood1234 said: We have a Jetpack Mifi 8800 that I think is wearing out after much use. The resolution on the TV is often blurry now even with an excellent signal. Up until a month or so ago all was fine. I bought a Verizon new in box identical replacement on Ebay. This isn't analog TV; all signals are digital. If there resolution is "blurry" it's not because the signal is too weak. It is possible that the data rate was so slow that your TV was defaulting to a lower resolution. Did you try using your phone as a hotspot to compare how well it performed (assuming that your phones are on the same carrier as the 8800)? The bottom line is that it could have been a poor cellular signal at the location where you were or there could be something wrong with the device. I would try performing a factory reset on it to see if that resolves some issues. Usually there's a recess you can get to when the battery cover has been removed. Hold down the reset button while restarting the hotspot. Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Bill Joyce Posted November 11, 2022 Report Share Posted November 11, 2022 It is also possible that Verizon made some changes in your local cell towers or there is a problem with a tower that needs to be fixed. Quote 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
lifeisgood1234 Posted November 11, 2022 Author Report Share Posted November 11, 2022 Thank you! I never thought about those other possibilities. I will try the phone as hotspot next time it occurs. Also the reset. Today all is perfect with the reception. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted November 11, 2022 Report Share Posted November 11, 2022 Initially we got the cheaper version. We're not happy with it. Went to Best Buy and got the 8800. All we did was change sim. Never an issue. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
chindog Posted November 11, 2022 Report Share Posted November 11, 2022 When my 8800L starts acting wonky, I swap out the battery with a new one, and that clears up the issues. Quote Mike and Retha Hopkins 2014 Fleetwood Discovery 40G Link to comment Share on other sites More sharing options...
lifeisgood1234 Posted November 18, 2022 Author Report Share Posted November 18, 2022 I did recently install a new battery. I'm going to be more diligent about rebooting it more often instead of running it days at a time(its on a timer with 4 short "on" intervals so as to not overcharge) and removing the battery once in awhile as suggested. Quote Link to comment Share on other sites More sharing options...
