GlennWest Posted August 4, 2022 Report Share Posted August 4, 2022 (edited) I have the Smart shunt and under battery settings most info not there. Has amp threshold and reset. No setting for amp hour or anything. Uninstalled and reinstalled and same. All negative cables go to shunt and then to bussbar. So all current used is thru shunt. I am not using nothing but dc to dc unit now but it should show a setting for ah for battery Edited August 4, 2022 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 4, 2022 Author Report Share Posted August 4, 2022 update. fixed I had to change a setting in it. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
