Lori W Posted June 21 Report Share Posted June 21 Looking for any suggestions on what could be used to block smaller items on the floor of 5th wheel, and going under the slide portion unknowingly. Such a tiny rocks, water caps, etc. Thanks Quote Link to comment Share on other sites More sharing options...
sandsys Posted June 21 Report Share Posted June 21 Maybe those rubber weather strip things you put under doors? Linda Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 24 Report Share Posted June 24 Our kitchen slide is not a flat floor slide but is an above floor slide style. We use this around the bottom. Its basically a long skinny foam rope like a pool noodle. We use the 1/2" size and it fills the gaps and keeps items from going under the slide. https://www.homedepot.com/p/M-D-Building-Products-1-2-in-x-20-ft-Caulk-Backer-Rod-71480/202066515 Quote Link to comment Share on other sites More sharing options...
