ashton23l Posted April 25 Report Share Posted April 25 I have a 2007 four winds hurricane 34b with the triton v-10. I want to flat tow a car behind it, but i cannot find anywhere that gives a number. I have a 5000 rated hitch, but i can change that. I am curious how much i can flat tow and where can i find that info. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 25 Report Share Posted April 25 (edited) You should not exceed the hitch rating. Usually the hitch rating is established by the the gas MH builder due to frame extension strength, and or drivetrain limits.. My cousin exceeded the 5,000# hitch rating and burned up 2 transmissions and 1 engine before he saw the light. Edited April 25 by Ray,IN Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 26 Report Share Posted April 26 (edited) Your owners manual for the chassis should give maximum towing weight and max combined weight. The one I used to own had all of the designed weight limits. Or it should be available from Ford if you search for wF53 chassis. Edited April 26 by Kirk W Quote Link to comment Share on other sites More sharing options...
ashton23l Posted April 26 Author Report Share Posted April 26 17 hours ago, Ray,IN said: You should not exceed the hitch rating. Usually the hitch rating is established by the the gas MH builder due to frame extension strength, and or drivetrain limits.. My cousin exceeded the 5,000# hitch rating and burned up 2 transmissions and 1 engine before he saw the light. The hitch was put in aftermarket, I can easily change out the hitch, how many toads are under 5000 pounds. i mean, that really limits the toad possibilities. thats where my hang up is. Quote Link to comment Share on other sites More sharing options...
durangodon Posted April 26 Report Share Posted April 26 1 hour ago, ashton23l said: The hitch was put in aftermarket, I can easily change out the hitch, how many toads are under 5000 pounds. i mean, that really limits the toad possibilities. thats where my hang up is. I would guess that most toads come in at under 5,000 lbs. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 26 Report Share Posted April 26 Most of the more popular towed’s are in the range of 4000# to 5000#. If you look at the Motorhome Magazine Dingy Towing Guides, I think you can get a feel for what is available at the different weights. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 26 Report Share Posted April 26 (edited) FMCA towing guides. I post that with a caveat; the ONLY 100% accurate recreational towing guides are each specific vehicles owners manual. There are many flat-towable vehicles under 5k#, even many Lincolns are under 5k# Edited April 26 by Ray,IN Quote Link to comment Share on other sites More sharing options...
