Rotorhead Posted April 12, 2022 Report Share Posted April 12, 2022 Hello All, What can cause an AC unit to continuously run other than having the fan in low or hi? It has been freezing up here and there. I fixed some leaks between then input and output side. Of course I don’t think that’s going to make it run non-stop. Is there a component up on the unit that might need replacing? I have already put a new thermostat and freeze sensor that goes into the evaporator. Chuck Quote Link to comment Share on other sites More sharing options...
TXiceman Posted April 12, 2022 Report Share Posted April 12, 2022 First and obvious question is....Did it do this before and after the new thermostat? Have you traced the signals to the roof and see where the power is applied to on the control board? Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Pat & Pete Posted April 12, 2022 Report Share Posted April 12, 2022 The relay on the control board has maybe gone bad . Pretty cheap ( about 10 bucks ) and easy fix if you're decent with a soldering iron . Or , just replace the board for a pocket full of money . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 12, 2022 Report Share Posted April 12, 2022 If it is a Dometic thermostat, try and reset it. Not sure if that work help or not. It could be a sensor if that unit has other Ac units hooked to the same thermostat. Post a picture of your thermostat Quote Link to comment Share on other sites More sharing options...
Rotorhead Posted April 12, 2022 Author Report Share Posted April 12, 2022 4 hours ago, TXiceman said: First and obvious question is....Did it do this before and after the new thermostat? Have you traced the signals to the roof and see where the power is applied to on the control board? Ken It did it before the new thermostat as well Quote Link to comment Share on other sites More sharing options...
Twotoes Posted April 12, 2022 Report Share Posted April 12, 2022 Is your thermostat set to auto? If it is set on fan (hi or low) it will continue to run. If set on auto it will stop when it reaches the temperature you set. Don't ask me how I know, lol. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Rotorhead Posted April 12, 2022 Author Report Share Posted April 12, 2022 41 minutes ago, Wrknrvr said: If it is a Dometic thermostat, try and reset it. Not sure if that work help or not. It could be a sensor if that unit has other Ac units hooked to the same thermostat. Post a picture of your thermostat Dometic LCD Quote Link to comment Share on other sites More sharing options...
Rotorhead Posted April 12, 2022 Author Report Share Posted April 12, 2022 10 minutes ago, Twotoes said: Is your thermostat set to auto? If it is set on fan (hi or low) it will continue to run. If set on auto it will stop when it reaches the temperature you set. Don't ask me how I know, lol. Ok thanks. I’ll give it a try. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 13, 2022 Report Share Posted April 13, 2022 Do you have more than one Ac unit on the rv. What thermostat did u replace. We need a picture of it or one like it. Did you do the initial setup when u installed the new thermostat. On the installation manual that came with the thermostat there should be instructions for to do the initial installation. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 13, 2022 Report Share Posted April 13, 2022 Sorry for the delay on this post. I apparently did not hit the post button yesterday. Did you replace the thermostat with the same kind. If you replaced a 4 or 5 button older style thermostat, It has to have the proper control board replaced on the side of the Ac unit on the roof. And if you have more than one Ac unit, then you need to replace every board with the proper one , so they will work with the new thermostat. Quote Link to comment Share on other sites More sharing options...
Rotorhead Posted April 16, 2022 Author Report Share Posted April 16, 2022 On 4/13/2022 at 9:04 AM, Wrknrvr said: Do you have more than one Ac unit on the rv. What thermostat did u replace. We need a picture of it or one like it. Did you do the initial setup when u installed the new thermostat. On the installation manual that came with the thermostat there should be instructions for to do the initial installation. I only have the one unit. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 16, 2022 Report Share Posted April 16, 2022 Did your old thermostat look like the new one you installed Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 17, 2022 Report Share Posted April 17, 2022 Some rooftop units will run the fan continuously and switch the compressor off/on as required to maintain temperature. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted April 17, 2022 Report Share Posted April 17, 2022 14 hours ago, Rotorhead said: I only have the one unit. Is this an RV that you have had for a while and the A/C used to work properly but this spring stopped, or might this be a new to you RV? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Rotorhead Posted April 17, 2022 Author Report Share Posted April 17, 2022 21 hours ago, Wrknrvr said: Did your old thermostat look like the new one you installed I replaced it with an exact match. Quote Link to comment Share on other sites More sharing options...
Rotorhead Posted April 17, 2022 Author Report Share Posted April 17, 2022 7 hours ago, Kirk W said: Is this an RV that you have had for a while and the A/C used to work properly but this spring stopped, or might this be a new to you RV? We’ve had this for about a year and a half now. It’s a 2017. It only had about 4,400 miles when we got it so I think it sat for most of its life until we got it. The first few trips it was pretty cold. Then it changed. I just checked the output temperature and it is only about 8-10 degrees cooler than outside temperature. The thermal overload protector was pretty hot. I don’t know if that’s normal or not and didn’t test resistance yet. This last trip I finally got an error code on the thermostat. “E1”. Some sort of communication error. Maybe the control board? Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted April 18, 2022 Report Share Posted April 18, 2022 4 hours ago, Rotorhead said: We’ve had this for about a year and a half now. It’s a 2017. It only had about 4,400 miles when we got it so I think it sat for most of its life until we got it. The first few trips it was pretty cold. Then it changed. I just checked the output temperature and it is only about 8-10 degrees cooler than outside temperature. The thermal overload protector was pretty hot. I don’t know if that’s normal or not and didn’t test resistance yet. This last trip I finally got an error code on the thermostat. “E1”. Some sort of communication error. Maybe the control board? The Delta/ difference between chilled air and intake/return air should be 20°F or a bit more. The ambient temperature of air outside the RV is immaterial. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Wrknrvr Posted April 18, 2022 Report Share Posted April 18, 2022 You may need to do the initial setup. That is if it was not done when you put the new thermostat on. You should have a paper instructions that came with the new thermostat. If not you should be able to get it online. With that done, see if it registers correctly. On some Dometic thermostats you had to do a reset occasionally to keep them working properly. Quote Link to comment Share on other sites More sharing options...
Rotorhead Posted April 18, 2022 Author Report Share Posted April 18, 2022 29 minutes ago, Ray,IN said: The Delta/ difference between chilled air and intake/return air should be 20°F or a bit more. The ambient temperature of air outside the RV is immaterial. Oh. Ok thanks. I didn’t know that. I thought it was the outside. I will have to take the measurements on the next warm day and when I have a day off. I start my week on hitch tomorrow. 48 minutes ago, Wrknrvr said: You may need to do the initial setup. That is if it was not done when you put the new thermostat on. You should have a paper instructions that came with the new thermostat. If not you should be able to get it online. With that done, see if it registers correctly. On some Dometic thermostats you had to do a reset occasionally to keep them working properly. I’ll have to look for the manual online. I am sure I tossed it. So much for the plug and play days eh? I did pull the styrofoam cover off after it had been running for a while. It had a little bit of frost along the top and a little along the bottom. Not enough to be frozen up. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 18, 2022 Report Share Posted April 18, 2022 6 hours ago, Rotorhead said: I just checked the output temperature and it is only about 8-10 degrees cooler than outside temperature. The way to check for proper cooling from the air conditioner compressor is to use a good thermometer(I recommend a dial type as available on Amazon) and measure the air temperature at the inlet to the cooling coils, then record that temperature and move the thermometer to the exhaust side of the cooling coils and measure it. The service manual recommends that the temperature be lowered by 18° to as much as 24° but no more as too much can cause a freeze up tendency as too little means the compressor isn't at full capacity or refrigerant may be low. They also say that service is required if the temperature change is less than 16°. While the outside temperatures do impact the interior temperatures the ability of the air conditioner to cool the RV is impacted by many things besides the air conditioner's operating. RVs then to not be the best insulated so heat gain from direct sun is far greater than in a house and there also is usually more hot air intrusion as well. Also things like dual pane or single pane windows make a big difference. But none of this really is likely to have much to do with the blower running all of the time, even if the inside temperature has fallen to or below the thermostat set point. Is it safe to assume that the blower does stop if you turn off the air conditioner? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Rotorhead Posted April 18, 2022 Author Report Share Posted April 18, 2022 10 hours ago, Kirk W said: The way to check for proper cooling from the air conditioner compressor is to use a good thermometer(I recommend a dial type as available on Amazon) and measure the air temperature at the inlet to the cooling coils, then record that temperature and move the thermometer to the exhaust side of the cooling coils and measure it. The service manual recommends that the temperature be lowered by 18° to as much as 24° but no more as too much can cause a freeze up tendency as too little means the compressor isn't at full capacity or refrigerant may be low. They also say that service is required if the temperature change is less than 16°. While the outside temperatures do impact the interior temperatures the ability of the air conditioner to cool the RV is impacted by many things besides the air conditioner's operating. RVs then to not be the best insulated so heat gain from direct sun is far greater than in a house and there also is usually more hot air intrusion as well. Also things like dual pane or single pane windows make a big difference. But none of this really is likely to have much to do with the blower running all of the time, even if the inside temperature has fallen to or below the thermostat set point. Is it safe to assume that the blower does stop if you turn off the air conditioner? Awesome information Kirk. Yes, the blower does stop when the system is turned off. If I adjust the temperature up some from say 72 to 75, it seems to cycle on and off as you would expect it too. Thanks again. Quote Link to comment Share on other sites More sharing options...
sheldons65 Posted April 20, 2022 Report Share Posted April 20, 2022 We ended up getting two of these and have been very happy. They are a little pricey but super easy to install. We love how they work and much better than the Dometic one. It does a much better job of control. Plus we can control the thermostat over the internet and via Bluetooth. Quote Link to comment Share on other sites More sharing options...
johnSm Posted April 29, 2022 Report Share Posted April 29, 2022 May be issue is in thermostat Quote Link to comment Share on other sites More sharing options...
