BOGART ENGINEERING Trimetric and Charge Controller
Bogart Engineering Solar Charger Control - $150 (N DARTMOUTH)
Solar Charge Controller
BOGART ENGINEERING SC2030 PWM Charge Controller with Trimetric TM-2030 / 500amp Battery Monitor
Current retail for both is $285......Selling for $150 shipped in lower 48 or pickup in SE Massachusetts.
SC-2030 CHARGE CONTROLLER
• Works with the TM-2030 Battery monitor as a 4-stage PWM charge controller to provide precise charging in accordance with battery manufacturer recommendations.
• Returns a measured amount of amp hours—and also has a higher voltage, current regulated finish charge to avoid battery undercharge or overcharge or sulfation.
• Connects to TM-2030 monitor with crossover-type telephone cable (included with each SC-2030) to access all settings and readings.
• 30 Amps maximum solar current, 12 or 24V systems, PWM technology at lower complexity and cost than MPPT technology with approximately the same efficiency
TRIMETRIC BATTERY MONITOR
• Most popular battery monitor for monitoring batteries in off-grid homes, RV’s or boats.
• Displays volts, battery amps, % capacity remaining & more.
• View history data to identify system problems.
• This is the A version for flush install.
$150 shipped to lower 48.....or pick up in Massachusetts
You will need a $10 cable to connect two units together......Available from BOGART ENGINEERING
YOU MUST EMAIL ME FOR A RESPONSE... rvb100 at comcast.net
Edited by rbertalotto
fix
 Share
RV Cable Grip
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
