ashton23l Posted April 1, 2022 Report Share Posted April 1, 2022 When i had my toy hauler I used a brass water regulator for city water connection, i used it with my 1999 class A also, but my new class A has a different fill valve, its a box and I believe its called quick fill, it has a hand on it to switch from fresh water tank to city water, do i need a regulator on it when on city water? Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted April 1, 2022 Report Share Posted April 1, 2022 Any time the city water hose connects directly to the RV plumbing, a pressure regulator should be used. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Kirk W Posted April 1, 2022 Report Share Posted April 1, 2022 You still have plumbing that will be endangered if you put excessive pressure on it. The plumbing is no different just the method of filling the water tank. The same regulator should work fine. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Danfreda1 Posted April 2, 2022 Report Share Posted April 2, 2022 I agree with using a regulator but some newer rv’s have pex lines just like in a lot of residential homes. I don’t think it’s wrong to not use it. It’s good for checking the pressure to see if your better off running off the pump. Quote Link to comment Share on other sites More sharing options...
lenp Posted April 2, 2022 Report Share Posted April 2, 2022 And place the regulator at the faucet - not on the RV end of the hose. I once checked into Fort Bliss RV park and discovered water pressure was over 180psi. I had neglected to hook up the regulator (I think I left in Brady) and, you guessed it, I sprung a leak - PEX pike by the way. The hose also had a leak in it. Here at my S&B I have city water at 120psi. House and RV both have regulators. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
57becky Posted April 2, 2022 Report Share Posted April 2, 2022 PEX is rated 160 PSI at room temperature, and I'm sure the fittings should be that also. The bigger issue is the plumbing fixtures. Also, if you use any type of water filter ahead of the RV, they are rated sometimes at 60 PSI, and a water hose is probably not any better, so that's why the regulator should always be the first thing connected at the hose faucet. https://plasticpipe.org/BuildingConstruction/BuildingConstruction/PEX.aspx Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 2, 2022 Report Share Posted April 2, 2022 11 hours ago, Danfreda1 said: I agree with using a regulator but some newer rv’s have pex lines just like in a lot of residential homes. One of the key words here is "some." In addition as pointed out above, even though PEX is being used a lot the fixtures have not been changed nor has the pressure testing standards of the RV industry. Just because an RV passed the standard 100# pressure test does not mean that it will hold 100# or more for days at a time since the test is only that it will hold 100# of air pressure for 15 minutes. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
durangodon Posted April 2, 2022 Report Share Posted April 2, 2022 9 hours ago, 57becky said: 60 PSI, and a water hose is probably not any better, so that's why the regulator should always be the first thing connected at the hose faucet. I generally agree. However, about fifteen years ago I bought a 30' water hose from the RV Filter Store with stainless fittings which is rated at 200 psi so that I could mount my pressure regulator and filters in a box in the RV basement. Hose wasn't cheap, but it's the only one I've had to buy and will probably outlive me. They no longer offer stainless fittings, but still offer the superior quality hose with brass fittings and rated at 200 psi. Quote Link to comment Share on other sites More sharing options...
Dutch_12078 Posted April 2, 2022 Report Share Posted April 2, 2022 2 hours ago, durangodon said: I generally agree. However, about fifteen years ago I bought a 30' water hose from the RV Filter Store with stainless fittings which is rated at 200 psi so that I could mount my pressure regulator and filters in a box in the RV basement. Hose wasn't cheap, but it's the only one I've had to buy and will probably outlive me. They no longer offer stainless fittings, but still offer the superior quality hose with brass fittings and rated at 200 psi. My Flexzilla hoses are rated for 150 PSI, and I still install my regulator at the faucet since there's no way knowing when a hose might be damaged in a way that would weaken it. And the excellent cold weather flexibility of the hoses is worth the lower pressure rating. Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
lenp Posted April 3, 2022 Report Share Posted April 3, 2022 When I sprung the leak at Fort Bliss it was not the PEX that leaked - it was one of the fittings (an elbow) in the PEX. Was not a big leak, just a drip, drip enough to get the compartment wet. Lenp Quote USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
