D&J Posted March 31 Report Share Posted March 31 We have two identical 5G phones on Verizon and was wondering if I can change both hotspots to the same password so I won't have to change things over on my connected devices like our Chromecast and printer. Denny Quote Link to comment Share on other sites More sharing options...
durangodon Posted March 31 Report Share Posted March 31 (edited) Yes. ON EDIT: Those other devices will still recognize each hotspot separately, not sure what you would gain by making the passwords identical except it might make them easier to remember. Edited March 31 by durangodon Quote Link to comment Share on other sites More sharing options...
Will B. Posted March 31 Report Share Posted March 31 What I would do, but this might be overkill for most (I'm a tech guy), is implement something like a Pepwave device, that provides an entire network. All the things connect to it's Wifi, and you never change those (we have 2x Echo devices, printer, laptops, the rig's networked stuff, a small server, and other little things, both wifi and hard-wired). Then, in the Pepwave, you give it multiple Wifi profiles, for example, I have a "saved" connection profile for every time I've used a campground's wifi (that was worth anything). If none of those are available, and it sees my phone's hotspot turn on, it connects to that. If my wife's phone's hostpot is on, and mine's not, it connects to hers, thereby providing network access to everything. In that situation, my phone connects to the Pepwave's wifi which is getting WAN service from her phone. Quote Link to comment Share on other sites More sharing options...
D&J Posted March 31 Author Report Share Posted March 31 2 hours ago, durangodon said: Yes. ON EDIT: Those other devices will still recognize each hotspot separately, not sure what you would gain by making the passwords identical except it might make them easier to remember. Didn't figure it would that easy. With our 5G Verizon plan each phone has 50GB phone data and 25GB hotspot data and our Chromecast is a pain to switch between the two. I may just buy another Chomecast and a HDMI splitter to make to make it easyer. I'm going to get a HDMI to USB C adapter so we can mirror the phone screen to the TV and use more of the phone data. For $10 more a month for each phone we can increase hotspot data to 50GB if needed. Denny Quote Link to comment Share on other sites More sharing options...
Bill Joyce Posted April 1 Report Share Posted April 1 I do what Will B Does using a Pepwave Surf SOHO router, but there are much cheaper travel routers from companies like GL.iNet (I have two models) and TP-Link that are under $50 that work fine. They are mostly sold for motel travelers to share the wifi or ethernet. GL,iNet and TP-Link travel routers are on Amazon. You can do an internet search for "best travel routers 2022" to get reviews. Quote Link to comment Share on other sites More sharing options...
trailertraveler Posted April 1 Report Share Posted April 1 (edited) I also use a router. The printer, multiple smart TVs and Roku devices are all setup to connect to it so that I never have to change their settings. The router I use is capable of connecting to 2.4 and 5 GHZ wifi, ethernet and by tethering a phone or tablet. I find that tethering provides faster speeds than connecting to the phone or tablet. 20 hours ago, D&J said: I'm going to get a HDMI to USB C adapter so we can mirror the phone screen to the TV and use more of the phone data. Before you buy the cable, make sure your phone supports the use of one. Despite specifically asking Verizon for a phone that supported HDMI, I found that the Samsung phone they sold me does not. I can mirror cast to my Roku devices by wifi and it counts as on device data. At times the connection is funky and has to be restarted. It also seems that the phone needs a faster connection when mirror casting than when viewing on the phone. It is my understanding that all I-phones support HDMI. Edited April 1 by trailertraveler Quote Link to comment Share on other sites More sharing options...
D&J Posted April 1 Author Report Share Posted April 1 27 minutes ago, trailertraveler said: I also use a router. The printer, multiple smart TVs and Roku devices are all setup to connect to it so that I never have to change their settings. The router I use is capable of connecting to 2.4 and 5 GHZ wifi, ethernet and by tethering a phone or tablet. I find that tethering provides faster speeds than connecting to the phone or tablet. Before you buy the cable, make sure your phone supports the use of one. Despite specifically asking Verizon for a phone that supported HDMI, I found that the Samsung phone they sold me does not. I can mirror cast to my Roku devices by wifi and it counts as on device data. At times the connection is funky and has to be restarted. It also seems that the phone needs a faster connection when mirror casting than when viewing on the phone. It is my understanding that all I-phones support HDMI. I will check on that, we went to Motorola phones this time because on my last two Samsung phones I had trouble with the USB ports, both old style and USB C. Denny Quote Link to comment Share on other sites More sharing options...
jpatrickc Posted April 1 Report Share Posted April 1 I use the same ssid and password on my home wireless and mt phone hotspot. That way all the wireless devices can be used with both with no changes to the connected devices. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted April 1 Report Share Posted April 1 10 minutes ago, jpatrickc said: I use the same ssid and password on my home wireless and mt phone hotspot. Which works fine as long as you don't have both on and in range of the same devices. We did that with our router in the RV and the house. Quote Link to comment Share on other sites More sharing options...
jpatrickc Posted April 2 Report Share Posted April 2 I usually only have the hotspot on when I am using it so it has not been a problem. Prevents all those push apps from using data. I'm not on an unlimited plan. Quote Link to comment Share on other sites More sharing options...
KodiakJack Posted April 6 Report Share Posted April 6 Both our phone's hotspots and jetpack have the same PW and have worked fine for years. Later, J Quote Link to comment Share on other sites More sharing options...
