GlennWest Posted March 5, 2022 Report Share Posted March 5, 2022 (edited) My Teton has a trim that separates the lower metal from the fiberglass at bottom of side wall. It has lost it "stick". Without it you see the seam and silicon. It actually been shrinking. I really believe it has been replaced before and inferior trim put back one. Would like to remove it and would be interested if anyone here has and made it look acceptable. ' Edited March 5, 2022 by GlennWest spelling Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Kirk W Posted March 5, 2022 Report Share Posted March 5, 2022 Could you clean it up well and put it back with the automotive double stick tape like they use for automobile trim nowadays? Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
GlennWest Posted March 5, 2022 Author Report Share Posted March 5, 2022 Yes. I can but it will still be short. There is about an inch gap at the ends now. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted March 5, 2022 Report Share Posted March 5, 2022 You could replace the trim with aluminum track with a vinyl insert. The track could be attached with the automotive trim tape that Kirk suggested. https://www.amazon.com/Insert-White-Aluminum-Length-Pieces/dp/B081VTWBK3/ https://www.amazon.com/Insert-Molding-Camper-Travel-Trailer/dp/B077H1L4N4/ Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
GlennWest Posted March 5, 2022 Author Report Share Posted March 5, 2022 That is interesting. Thanks. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted March 6, 2022 Report Share Posted March 6, 2022 13 hours ago, GlennWest said: That is interesting. Thanks. That trim and insert is what our manufacturer used on our trailer when it was built, except that it was black. After they screws the trim on, the coated the screws near the ends with sealer and also used a screw thru the insert at the ends to keep it from moving in the track. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 6, 2022 Report Share Posted March 6, 2022 On 3/5/2022 at 8:32 AM, Dutch_12078 said: You could replace the trim with aluminum track with a vinyl insert. The track could be attached with the automotive trim tape that Kirk suggested. https://www.amazon.com/Insert-White-Aluminum-Length-Pieces/dp/B081VTWBK3/ https://www.amazon.com/Insert-Molding-Camper-Travel-Trailer/dp/B077H1L4N4/ Here's a much better price for the same^ : https://www.ebay.com/itm/274274301274 Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
GlennWest Posted March 6, 2022 Author Report Share Posted March 6, 2022 Actually I got double sided tape and put back on. It is short but looks ok for now. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
