Bluefire for diesel
11 hours ago, Ray,IN said:
Thanks for the information, I cannot use it though. I have a 6-pin 1999 chassis and that link says not for a MH.
Ray, we used this on our 2002 Dutch Star 4097  spartan chassis/ Cummins 350. Worked like a charm. The plug has 9 pins but if you look close at the picture you'll see that only 6 pins have connectors. If you look at your data port on your coach that's the pins that feed data to the bluefire.
1 hour ago, Ray,IN said:
I'll have to check the under-dash plug again.
Does this 9-pin to 6-pin adapter come with your Bluefire?
Only thing i have is what's pictured. You should be able to find any info you need on Bluefires web site, they have tech support as well as a forum that can answer your questions. I'm far from an expert about these and don't want to give you bad info. I know it worked well in our application.
 Share
