CalebJ Posted February 8 Report Share Posted February 8 I have a 2012 Keystone Cougar, and have recently had issues with my heater not maintaining the temperature I set the thermostat to. It will turn on initially, but after it reaches that desired temperature, it won't kick back on. I typically have to turn the system off, then back to heat in order to get the furnace going again. If the heater has been running and then stopped running, I can turn the desired temp to max and the furnace still won't kick on. I replaced the analog Coleman Mach thermostat today, (having read a bad thermostat could cause this issue), but no luck. Propane tanks are full, I tried swapping the tanks just in case. Would appreciate the help, got a one year old I'm trying to keep warm in below freezing temperatures at night. Thanks! Quote Link to comment Share on other sites More sharing options...
Kirk W Posted February 8 Report Share Posted February 8 8 hours ago, CalebJ said: Would appreciate the help, Welcome to the Escapee forums! We are here to help so will do the very best that we can to find a solution. Based on what you have shared my first suspicion is that your furnace needs the ignitor probe replaced. Without knowing what make and model your furnace is, it is difficult to diagnose for sure but that is a very common failure in most brands/models of RV furnace that is in the 10 year old range. You probably have either an Atwood or a Suburban furnace. Has it been working properly until recently? How long has it been since the furnace was cleaned and serviced? Are you connected to 120V shore power? If you can share more information it will be helpful in narrowing the possible causes of they problems. Quote Link to comment Share on other sites More sharing options...
TXiceman Posted February 8 Report Share Posted February 8 There can be a number of issues that can cause your problems. But in order to help you the best we will need to know the make and model of the furnace. Most of us do not know what furnace was used in a 2012 Cougar RV. It could be a high temperature sensor locking the furnace out until the thermostat is reset. Ken Quote Link to comment Share on other sites More sharing options...
Kirk W Posted February 13 Report Share Posted February 13 On 2/7/2022 at 11:11 PM, CalebJ said: I have a 2012 Keystone Cougar, How about an update to know if we have helped you any? If not give us a bit more information and we probably can. Quote Link to comment Share on other sites More sharing options...
KodiakJack Posted February 19 Report Share Posted February 19 (edited) Worth mentioning is that some thermostats, such as the Dometic's, can have their on/off set point or delta adjusted. When set to 3-degrees it can feel quite cool before restarting the furnace especially in an RV that is less than weather tight. Tried to post Dometic's pdf instructions for reprogramming but it was was too big. Later, J Edited February 19 by KodiakJack Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted February 19 Report Share Posted February 19 2 hours ago, KodiakJack said: Worth mentioning is that some thermostats, such as the Dometic's, can have their on/off set point or delta adjusted. When set to 3-degrees it can feel quite cool before restarting the furnace especially in an RV that is less than weather tight. Tried to post Dometic's pdf instructions for reprogramming but it was was too big. Later, J You could simply post a link to that pdf , maybe ??? Quote Link to comment Share on other sites More sharing options...
KodiakJack Posted February 22 Report Share Posted February 22 On 2/18/2022 at 7:09 PM, Pat & Pete said: You could simply post a link to that pdf , maybe ??? Sorry only have a pdf file I downloaded from somewhere years ago.. Later, J Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted February 22 Report Share Posted February 22 6 hours ago, KodiakJack said: Sorry only have a pdf file I downloaded from somewhere years ago.. Later, J OK , Thanks anyway . Quote Link to comment Share on other sites More sharing options...
