Lance A Lott Posted October 9, 2021 Report Share Posted October 9, 2021 (edited) Cant get to sleep so I thought I would tell you my tail. The trip start fine for the first 7 or 8 hours all secondary roads everything seemed fine, then we got on the interstate. Thismis the first time I have had this truck on the interstate with a trailer since I bought it 4? Years ago. It is the worst handling vehicle I have ever driven it feels articulated and has a bad shake between 50 and 60 then stops by 65. We are moving and I didn't have much choise so keep going. Even my wife asked me why the truck was all over the road. About 2 hours of white knuckle driving down the interstate and the truck shuts off and a no oil light comes on. I got it to the side of the road and sure enough no oil on the dipstick but my trailer and the underside of the truck is covered with it. It seams to be comming from the crank case vent. I had 1 gallon with me and that got it started and to them next exit. There was a truck repair shop at the bottom of the exit. Did I mention I am moving, I have 4 horse 2 dogs a parrot and a parakeet in the trailer and its 95 degrees out. The shop was able to fill me up with oil another 4.5 gallons and sell me 4 more but they dont do big stuff, they also knew a stable and she agreed to have me limp there to get the horse about of the heat. The next day I took the truck to a recomended shop they decided, withou looking at it, that in 2 weeks they could do an in frame as they felt it was bad rings. I had clapped a camera under the truck and you could,see the oil pour out the vent every time you worked the engine. I am not new to engines or equipment and there "diagnosis" seemed off to me it was a stream of oil not a mist as I would expect from a bad ring also it was running great just going through 2 gallons of oil every 100 miles. So I called the Volvo dealer in Vermont in two minutes he said it was the spinner. I had to admit ignorance. It's a Volvo D11 by the way. He sId if it's working I should be able to hear it spin just step on the gas and and it off, I heard nothing. I called the nearest Volvo dealer, 35 mile, and they had one $1200. So filled it with oil and drove over picked it up and drove back. The nice aluminium braket didn't want to release the steel screws holding it to the block so I decided to leave that part and just replace the top portion. The old one was solid and the new one spins with just a touch. It's a oil centrifuge run by a jet of oil on a wheel. I never lost a nother drop of oil. I played with my hitch, tire pressure and load distribution but it still handles horable. It's not tracking the ruts it just feels like the rear end is loose. Passing is an absolute nightmare. I have picked up a tourqe bar and will be checking spring bushing this winter. I sure wish I had left it tandem now. And now I have misplaced the only key for the 08 Smart. I will never move again! Edited October 9, 2021 by Lance A Lott Spelling Quote Link to comment Share on other sites More sharing options...
Parrformance Posted October 9, 2021 Report Share Posted October 9, 2021 So sorry to hear of your misadventure. I am thankful it was a $1200 part and not a $12000 in frame. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Parrformance Posted October 9, 2021 Report Share Posted October 9, 2021 https://manage.kmail-lists.com/subscriptions/web-view?a=XT9tNY&c=01FGMV6RX6M6F2ABWF5ECJTTPP&k=0b0038c6a54a9c9ce7c7ca168bc6ce94&m=VikspC&r=GJVUgbx Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
lappir Posted October 9, 2021 Report Share Posted October 9, 2021 Are you able to post a photo of the truck and trailer from a side view? Preferably on a very flat surface. Not sure I would see anything, but others might. Sorry to hear of your issue. Hope it get's better soon. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
noteven Posted October 9, 2021 Report Share Posted October 9, 2021 Hi Lance - Moving, complete with animals, is never straight forward it seems. I know in the RV world we are not used to particularly good after the sale support from dealer organizations. Your centrifuge story is a good reminder why to not necessarily dismiss dealer support for mystery issues with heavy trucks. Handling troubles - when you get time please reply to these questions - something might come to light you can investigate further: 1. What cold psi tire pressures are you running front and rear? Are the wheels and tires in balance? 2. You mentioned "left it tandem...". What was the original wheel base - steer axle to center of tandems? What is the finished wheelbase - steer axle to center of rear axle? When your truck was "singled", were the ackerman arm and driveline angles checked to be within spec and a complete chassis alignment done? When you get a chance to uncouple the trailer and test drive on the same road that you last experienced bad handling with the trailer, is the problem still there? If the problem goes away when you are bob tail, is the trailer alignment correct? If the problem(s) are more or less the same bob tail or towing your trailer: 3. Are all steering linkage components tight within spec? Is there any unusual tire wear pattern? 4. Are all wheel bearings tight end play wise? 5. Are all suspension bushings and mounts tight and within spec? 6. Are your cab suspension dampers (shock absorbers) in good shape and functioning? There is a tire coupled testing machine some shops may have commonly called a "shaker". It applies lateral force to the tires and any worn beyond spec parts in 3 to 6 above become readily apparent. 7. Are your seat mounts and mechanisms reasonably tight? Some air seats have some side to side slop from new. No idea why. Adds to the bobblehead motion/human discomfort when the steer axle ducks around on rutted roads. Anyways unless parts are obviously worn out CSI is needed before throwing parts at the issue(s). Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
rickeieio Posted October 9, 2021 Report Share Posted October 9, 2021 And then there's the possible issue of a light hitch weight........ Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
dennisvr Posted October 9, 2021 Report Share Posted October 9, 2021 9 hours ago, Lance A Lott said: bad shake between 50 and 60 then stops by 65. Every time I've encountered this, it was wheels out of balance. Have them balanced and it should go away. I dont know what brand of the 10 yr old tires that were on 2001 Volvo 660 when I got it, I put a set of used Michelins on and dont remember any wandering with them. I put a set of Sailums on it and played with the pressures from 80 to 110 psi and it still wanders all over the road. Quote "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Sculptor Posted October 10, 2021 Report Share Posted October 10, 2021 (edited) I had a bad vibration at 41-45 mph and it was worn tires. Either out of balance or cheap dealer shocks or both. On a pickup truck, you can tell if there is play in the front, while sitting still and kicking the tires etc. Does anyone have a trick for a semi? Seems like you would at least have to get that tire off the ground. I’ve never tried it, am I dreaming? Edited October 10, 2021 by Sculptor Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 10, 2021 Report Share Posted October 10, 2021 (edited) This is some things to check or do that should be fairly easy to check. First thing to check would be the tread wear on the front tires. Then jack the passenger front tire off the ground. Check to see if the wheel will move in and out at the top. If there is movement is it wheel bearings. Or is it king pins. With the wheel still jacked up can you wiggle the tire left to right. If so there maybe wear is the tie rod ends. If there is play in the king pins or tie rod ends you could grease them for a temporary fix. May need to grease them a few times on your trip. Check the drivers side wheel bearings also. Then grease all fittings on the front end. Also look on the edge of the tire next to the rim. There could be a small ridge of rubber standing up. It should be equally spaced all around the rim. That will show if the tire is centered on the rim. I hit a really bad pothole going through Richmond Va years ago and then the truck started to give problems in the front end. Went to a tire shop and tech looked to see if the line was still the same. It was still the same. Pothole injured the tire. Installed a new set of steer tires. Hope this helps, Vern Edited October 10, 2021 by Wrknrvr Quote Link to comment Share on other sites More sharing options...
Star Dreamer Posted October 11, 2021 Report Share Posted October 11, 2021 Do you have the air ride front suspension or just leaf springs? I have heard that the airride front gives a floating feeling. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 11, 2021 Author Report Share Posted November 11, 2021 Sorry I havent gotten back to anyone I have this site on a tablet and I just got internet this past weekend so I charged it up. Many of the suggestions were on my list but some were not so thanks everyone for your input. A few I can answer now. It's better bobtailing but not much that may be because I can't go as fast as on the interstate. Tires don't seam to have any odd wear I haven't had anything balanced or aligned. Wheel base is 182 and was 230 ish, it's been 4 years so the memory may be off on that, I just moved the rear axle to the front to single. At the present I am working around the house so I would not have time for any research, I also live in the sticks, thank goodness, so it will take some time to learn who to go to in the area. Quote Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 11, 2021 Author Report Share Posted November 11, 2021 Forgot I found the Smart key now to find someone who can cut a new one. I also need a rear rim I will start a new post with a picture, I hope. One has a crack in it very small but it leaks air, or did until I put some great tape on it. Quote Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted November 13, 2021 Report Share Posted November 13, 2021 A Locksmith will need to be able to laser cut the key. Once it is cut, it will need to be programed to the car. If your locksmith can't do that, find a tech with a good Snap-on scanner. They can program your key in just a few minutes. I only had one key for our 2015 but ordered 2 new keys from Germany and programed them myself with my scanner. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Max Speed Posted December 6, 2021 Report Share Posted December 6, 2021 I had a bad torque bar, the back of the truck felt like I was on ice. truck would sway from side to side going down the road. It was something I put up with for several years. Each year the truck passed inspection, I thought it was something I had to live with. I changed repair shops and the new shop caught it right away. What a difference that made, night and day. It sounds like you're on the right track. Quote Take it to the limit one more time! Link to comment Share on other sites More sharing options...
rickeieio Posted December 6, 2021 Report Share Posted December 6, 2021 1 hour ago, Max Speed said: had a bad torque bar, Duh, I should have remembered that one. I changed the dog bones, suspension links on our Mack a few years ago and the difference was amazing. Easy job, with no bed. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Lance A Lott Posted December 19, 2021 Author Report Share Posted December 19, 2021 I bought a new torque bar from the dealer in Vermont before my last trip to Arizona, with the 1 ton Duramax this was a dream trip in comparison to the Volvo the trailers were almost identical weight. Now just need time to install. Quote Link to comment Share on other sites More sharing options...
porky69 Posted December 29, 2021 Report Share Posted December 29, 2021 For the shake at 50-60mph...did you have the driveline and pinion angle recalculated for the shorter wheelbase and one less axle. Rear drive axle has the pinion in a different position as compared to the original forward axle and this will change all of the driveline angles, which may cause vibration. You may have to shim the drive to adjust the pinion angle and/or adjust the hanger bearing height. If the track bar or any other suspension bushings are shot they need to be replaced before changing pinion angle as they are inter-related Quote Link to comment Share on other sites More sharing options...
ARGO Posted December 29, 2021 Report Share Posted December 29, 2021 If you had the driveshaft redone, lenghtened whatever- my guess for your shake at 50-60 is that the bearings are out of phase. You can do a rough (very rough) guess at that by taking a string and laying it centered on one bearing cap, then taking the other end across the other cap. The string should run dead center across both caps. Note this a shade tree check, it could still be off several degrees and you wouldn't see that, needs a machine shop & lathe. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
